Fueling & Injection - 1000+ wrhp fuel pumps help
Kwt_DragerZ
11-04-2009, 02:37 PM
Hi All ,,
Now i'm installing my fuel system , injectores , fuel pumps and every thing in extrem performance garage in kuwait ( The best garage in kuwait ) do by the top tuner faisal dashti ;)
Now , i want to know does the BOSCH 044 Inline pump and Walbro
255L with 96# Injectors handel more than 1000 rwhp ??
please calculate and tell me as soon as you can guys ,,
stay tuned with my big S91 kit and you will see the Spool:corn:
396375
11-04-2009, 05:54 PM
Hi All ,,
For what it's worth why not put another 044 on.
Good luck.
Kwt_DragerZ
11-04-2009, 06:16 PM
Because when i put another bosch 044 the pump sound will be loud ,,
so please i want you to tell me how many rwhp can i get with my setup without leaning out ??
THanks
396375
11-04-2009, 08:39 PM
No it won't.ECS makes a similar system and say it's only good for 800 RWHP.If you are mounting the Bosch pump externally you should activate it on a Hobbs switch to avoid the noice and heating up the fuel.Don't chance it.Add another Bosch.
http://www.eastcoastsupercharging.com/Custom%20Fuel%20System.html
http://www.ls1tech.com/forums/fueling-injection/293742-fuel-injector-size-calculator-fuel-pump-chart.html
Call Lonnies for the right setup.
Kwt_DragerZ
11-05-2009, 12:38 PM
Thanks a lot for your help ;)
Nasty N8
11-05-2009, 05:03 PM
It should do about 1000-1100rwhp along with that Walbro. as long as both pumps are parallel and as mentioned trigger the Bosch with the boost.
ECS kit mentioned is rated at 800 to be safe because it uses a factory fuel pump not a Walbro.
396375
11-05-2009, 05:56 PM
There ya go.From the expert.I still wouldn't chance it for the amount of money involved.
Good luck.
dreamls1
11-06-2009, 11:07 AM
I am going with a magna fuel pump, good for over 2500hp, plenty of fuel :)the pump is quite too.
onfire
11-06-2009, 12:14 PM
If the walbro is feeding the Bosch pump, it will not be safe at 1000rwhp. Two parallel Bosch pumps would be very safe.
