Generation IV Internal Engine - LSX-R GM heads?
View Full Version : LSX-R GM heads?
Stangkilr
11-04-2009, 02:51 PM
Im thinking about ordering the LSX-R LS3 heads that GM has came out with. My question is they have the extra bolts for the LSX block but can I still use them on an LQ9 without them bolts?
427
11-04-2009, 02:55 PM
The original 10 bolts in all "6" bolt heads are in the conventional spot, so you can use a 6(18) bolt head anywhere a 4 (10) will go.
Kurt
John@Scoggin
They heads that are surfacing first are supposedly going to be the LSX-LS7 heads. I have no ETA on the LSXLS3 heads atm. You could use them on a regular block yes, just do not use the bolt holes.
Stangkilr
11-04-2009, 03:39 PM
Thanks John for answering all my questions.
John@Scoggin
11-04-2009, 04:04 PM
No problem
Stangkilr
11-04-2009, 06:37 PM
I went with the ported L92's from GM....John I will be calling you to order the intake, studs and gaskets.
John@Scoggin
11-04-2009, 06:38 PM
Great! Ill get you fixed up.
Jontall
11-05-2009, 05:31 AM
Are there any pictures of this head?
