Florida Members - Painting my valve colvers
The SSheriff
11-04-2009, 05:19 PM
Just had a few quick questions:
1. What paint do I use? What clearcoat do I use (if any)?
2. What is the application method? I know I have to scratch up the surface, but do I apply all of my coats of paint BEFORE clearcoat, or do 2-3 coats, then clear?
Furthermore, just as a quick reference. My engine bay is white, my coil pack brackets and strut tower brace are red. Do I go with white, red, or black?
Any help would be appreciated.
N2OMIKE
11-04-2009, 05:47 PM
Get em powdercoated!!
WS6nJAX
11-04-2009, 05:50 PM
what he said. spend the extra $$$ and have it done right.
The SSheriff
11-05-2009, 10:12 AM
I'd like to do it myself. Anyone have the procedure?
GRN ENVY
11-05-2009, 10:28 AM
Any Paint on them now?
maverickmk
11-05-2009, 01:20 PM
scuff them, paint them, clear them
DozerDan
11-05-2009, 02:23 PM
I put 2 coats of 500* primer then 2 coats of filler primer to get them real smooth. 2-3 coats of whatever color you're gonna use then 2 coats of 500* clear. Mine have been like this for 6months as a daily driver and still look just as good as the day I put them on
DozerDan
11-05-2009, 02:28 PM
I painted my valve coveroilfield rails, oil brackets, coils, front cover and intake manifold all the same way. On the plastic parts(intake and coils) I used and adhesion promoter before the first coat of primer
http://i220.photobucket.com/albums/dd112/fastlane_03/DSCF9421.jpg
http://i220.photobucket.com/albums/dd112/fastlane_03/DSCF9424.jpg
The SSheriff
11-05-2009, 07:15 PM
Thanks for the tip. What is the drying time between coats, or are the instructions on the bottle?
Corvettekid82
11-07-2009, 01:02 AM
Here ya go man: http://www.installuniversity.com/install_university/installu_pages/donations/painted_valve_covers_bh.htm
Should be all the info you need.. and follow the drytime info on the can of paint you choose. I used duplicolor 500* ceramic paint and clear coat and you've seen mine in person. Holding up fine! I would go with red or black on your setup if it were me.
The SSheriff
11-08-2009, 01:16 AM
Here is a pic of my engine bay.
http://i52.photobucket.com/albums/g37/Ragingwolf51/Engine1.jpg
Which should I do?
white valve covers/red coil pack brackets/black coils
white valve covers/red coil pack brackets/white coils
black valve covers/red coil pack brackets/white coils
black valve covers/red coil pack brackets/black coils
Corvettekid82
11-08-2009, 11:52 AM
If I had to choose from just those options: black valve covers/red coil pack brackets/black coils
I still vote for red valve covers/red coil pack brackets/black coils
toadzq8
11-09-2009, 07:33 AM
Black valve covers and silver coil brackets
http://i204.photobucket.com/albums/bb218/toadzq8/valvecovers003.jpg
teke184
11-09-2009, 08:15 AM
dupli-color 500* engine enamal
used striper to remove old paint (bad job), scuffed up then painted.
several coats, maybe 30min between each.
could have been smoother, but with how much is covered, decided it wasn't worth the effort.
got a few small "fisheyes" on them, not sure how. totally degreased them in the prep process.
http://i21.photobucket.com/albums/b281/keezdiver/camaro/P3100001.jpg
http://i21.photobucket.com/albums/b281/keezdiver/camaro/P3100004.jpg
http://i21.photobucket.com/albums/b281/keezdiver/camaro/P3100009.jpg
http://i21.photobucket.com/albums/b281/keezdiver/camaro/P3100015.jpg
The SSheriff
11-11-2009, 09:05 AM
Thanks for all the advice. I can see a lot of you are using the same color for the valve covers in regards to the engine bay. I am going to go with white valve covers for sure, red coil pack brackets, and white coils.
I'll post pictures as I go.
Thanks again.
The SSheriff
11-12-2009, 09:58 AM
Thanks again everyone for all of the help. I took my time and the covers came out flawlessly white. Today when the humidity drops I am going to paint the coils.
Pics to come soon!
candlelit
11-14-2009, 01:57 PM
hope that white holds up for you & doesn't start turning yellow anytime soon. I'm nearly in the same process (white engine bay) and can't decide between white or black.
can't wait to see some pics! :thumb:
The SSheriff
11-17-2009, 09:07 PM
http://i52.photobucket.com/albums/g37/Ragingwolf51/Driverside.jpg
http://i52.photobucket.com/albums/g37/Ragingwolf51/Passside.jpg
