billscamaros
11-05-2009, 10:54 AM
time for some maintenance on the 99 z28.
i am using synthetic diff and trans fluid.
Number of ounces of fluid for the manual transmission?
what weight of fluid for the differencial?
175K miles on the car.
thanks
91RS383
11-05-2009, 12:18 PM
The weight of the diff fluid is in the owners manual 75w90 I believe. Buy a good synthetic that says it has limited slip additive so you don't need to worry about that.
I use RP. Some sources say it doesn't last as long as others. Mine gets changed once a year which is about every 1,000 to 1,500 miles. I do get better MPG with RP over Valvoline or Castrol.
I buy a dif gasket and coat it on both sides with grease. This goes on easier and cleans up better than using RTV.
billscamaros
11-05-2009, 07:34 PM
thanks david. i've always used the diff additive ... i'll have to check the RP tech literature out.
