Conversions & Hybrids - Chevy II Nova Ls1 Header
pimpdulla
11-05-2009, 04:15 PM
For those looking for Ls1 Headers with the heidts front Shoenfeld Headers will work perfect,I just brought a set prt#186Ls1-3.I paid $268 delivered to my door today.Look at my album for pictures.The Headers are $249.95 1 3/4 Long tube.I'm trying to help everybody so that you don't have to spend all that damn money for a good header.
JDishong
11-05-2009, 04:38 PM
Dont see any album
pimpdulla
11-05-2009, 05:17 PM
It's there I have eight pictures.
JDishong
11-05-2009, 11:56 PM
Here's a link so people don't have to look through 1000+ pages to find the pictures :/
http://www.ls1tech.com/forums/album.php?albumid=12972
LS2 67GTO
11-06-2009, 10:09 AM
What motor mounts are you using? Do you have any shots from the side that show how far they are hanging down? I am putting bags on mine and want to be able to slam it.
Thanks.
pimpdulla
11-06-2009, 12:34 PM
The adapter plate are from Trans dapt #4572,and the motor mounts are the short/wide sbc mounts for First generation sbc,from looking at the pictures the headers don't hang low(perfect,side by side to the trans pan),the lowest thing under the car is the oil pan(LQ9 truck pan).Slaming shouldn't be a problem far as headers are concern.
ChrisBorsheim
11-06-2009, 03:51 PM
Great info!
I assume these will fit for a TCI clip on a 63 Nova. Does it have the bugs for the O2 sensors on them?
pimpdulla
11-06-2009, 07:12 PM
No oxygen bugs,no collector flanges
pimpdulla
11-06-2009, 07:23 PM
Look at the pictures,They come just as seen in the pictures,I had just pull them out the box.I'm going to order some 3'' flanges,and some collector with oxygen bung already installed.
joshluther
11-07-2009, 08:22 PM
Can you send me a PM with the info from where you bought them.
pimpdulla
11-08-2009, 01:21 AM
Just go to Shoenfeld Headers.com or call them like I did (479)474-7529 Prt#186Ls1-3
71 chevy
11-08-2009, 02:21 AM
I get my schoenfeld parts from smileys racing in mesquite tx, about a 25 min drive from me.
I dont belive schoenfeld sells to the public, you have to call them and get the dealer nearest to you. that said, they are VERY affordable.
pimpdulla
11-08-2009, 12:07 PM
Well all I can do is tell you what happen to me,I call them,Asked for this prt#186ls1-3 they asked me if I had a account,I said no, I just want to buy a set of headers and they sold them to me,asked if I wanted to do a C.O.D or charge card,I used my charge and they Fedx them to my door.I don't think it get much simpler than that,Hey it work out fine for me.
Mike in Motown
11-08-2009, 07:20 PM
Thanks for posting this. Im trying to figure if they will fit my TCI clip.
Are they close to hitting anything, anywhere?
pimpdulla
11-09-2009, 01:02 PM
Well on my 67 nova with the heidts front clip they clear everything like you would want them to 100%.Now for the TCI front clip I would think so but not 100% sure,I've been told that the TCI frame rails are narrow so I don't know if that is on the inside or the outside of the engine bay.If it was mind I would try it because,if the frame rails are narrow I would think that might give me even more clearance so I would try them.
Wish I would have known about these sooner, could have saved some bucks.....oh well.....nice find for sure, thanks for sharing the info.
T,
Mike in Motown
11-09-2009, 10:35 PM
It looks like its going to be tough to get the plug wires on?
pimpdulla
11-11-2009, 12:14 PM
Wires is not a problem,I think that the car wires are first choice,because the truck wires are longer,and on the passenger side short wires are best because of the way the tubes are bent.
Chevy II
11-15-2009, 01:13 AM
Do you have any pictures of the trans mount? Looks like you are using the stock mount. Did you relocate it back, modify it or use something different?
Did anyone find out if these will work with the TCI clip? TCI clip is narrower at the firewall than the other clips.
Mike in Motown
11-15-2009, 06:30 PM
Are we going to flip to see which one of us orders a set to see if they fit the TCI clip?
Also, im still not seeing how you get the plug wires on without running them over then under the header tubes on some cylinders which I wouldnt want to do.
pimpdulla
11-15-2009, 07:20 PM
I'm going outside to take some more pictures,just give me a minute.I started up the car last night for the first time,I'm happier than a Mutha right now.
pimpdulla
11-15-2009, 09:02 PM
New picture are posted now for as the header wire clearance question,I'm going to get some new wires.I used the stock crossmember,I had to modify it a little far as the holes on the trans mount,they were a little different from were the mount was .The mount was closer toward the engine than the rear end so I drilled the crossmember and bolted it up,problem solved.
