New LS1 Owners - Newbie Tech - Is the corsa pro-series 4" ..product 14148 really worth $1000.00
SSCAMARO02LS1
11-05-2009, 08:14 PM
I have done some research, and if Lingenfelter uses Corsa it has to kick a--. But is it really worth $ 1000.00 ? And what is a good y-pipe to use. Any help would be appreciated.
Picked her up in june--65,000 miles..SLP # 2210, very well taken care of. Added SLP lid, has loud-mouth II but its factory and not quite as mean sounding as I want.....need y-pipe,catback,and a nice tune--screw the handhelds--Custom Tune only.
OSU Football Fan
11-05-2009, 08:42 PM
No, The Corsa exhaust isn't worth $1,000. Magnaflow will
perform as well for less than half the price.
It's an awesome sounding exhaust though.
Do longtubes & a matching y-pipe or keep your stock y-pipe.
BTW, the factory SLP exhaust would be the dual dual catback.
The LM2 is an aftermarket unit.
SSCAMARO02LS1
11-05-2009, 08:57 PM
Yep its the dual-dual..sounds o.k. but needs more.
Thanks man.
RPM WS6
11-05-2009, 11:02 PM
Is it worth $1000? Well, "worth" is a relative term. In terms of power per dollar, it's not worth anywhere near $1000, when you consider that a well placed cutout will provide similar gains for $30 and the cost of welding. On the other hand, if you love the look, sound, fit & finish, etc., then it might well be worth the money for those who can afford it.
The catback on my '98 Z is a Bassani, which is pretty pricey too (I think near $800 these days?), though back when I bought it they were about $550. I liked the sound, fit, and quality...but if the question is, was it worth it just for the power.... the answer is no. Would I buy it again though? And was it worth it for the quality/fit/sound? Absolutely on both counts. If you're on a tight budget though, go for a cheaper system.
Gordon0652
11-05-2009, 11:21 PM
I personally had the corsa and only took it off because i am rebuilding the entire car.
I LOVE THE SOUND!!! Its totally worth the 1g.
Detoxx03
11-06-2009, 12:21 AM
I think its worth it but if your on a budget take a look at the PowerFlo system or throw an e-cutout on yours cause once you start putting lt's and h/c it will get louder.
hitmanws6
11-06-2009, 12:40 AM
you can do with just the muffler for now. you have a lot of options. as far as the y pipe, SLP makes a "smoother" y pipe, but you can go with TD's and keep the factory cats in place
SSCAMARO02LS1
11-06-2009, 03:20 PM
Thanks to all your replies and good response on " Worth " there RPM..I would rather pay a little more and be happy then to pay $ 500.00 and think it sucks..Some people say, and I believe that u get what u pay for-- but I just wanted some other opinions.
You guys Rock..Any advice on a good Cam would be helpful as well.
Nothing major just a good streetable cam.
Theres NO Replacement for Displacement - The LS1 is a great motor.
Gordon0652
11-07-2009, 10:28 AM
Yes there is, FI... :chug:
RPM WS6
11-07-2009, 12:00 PM
Until you add FI to the bigger displacement motor. ;)
camaroracer91
11-07-2009, 01:27 PM
a great streetable cam would be a 224/224 cam or even a 228 cam
thewholefnshow1
11-07-2009, 02:52 PM
What's said above or a VRX3 or a custom 224/228 grind
SSCAMARO02LS1
Just a quote that stuck in my head ---I get it...Thanks 4 the advice on the cam there 91 and fn.
I have about $2000 - $2500.00 right now to get this car started..There is a local shop here called Chuck's Speed Shop in Phoenix that has a good history and nice equipment..
LT Headers, SLP Y-Pipe, Corsa Pro-series Catback then a good tune, or Cam it then get the tune.....and if I am going to Cam it...might as well throw a Stall in Right??
So much to do, so little time.....Looking 4 a reliable 11 to 11.5 second daily driver.Not too much to ask huh!?!
socalfastV
11-07-2009, 03:28 PM
I have Corsa. As stated you could get magnaflow exhaust with around the same build quality, but Corsa's "note" and sound are un-matched.
sway99bird
11-07-2009, 03:53 PM
NOOOOOOOOO......IMO it really just depends on what you want and your pocket book as well...
thewholefnshow1
11-08-2009, 12:11 PM
sway99bird from the looks of your picture, Your raising your girl the right way. lol
twitchtwice
11-08-2009, 02:09 PM
if i were you i would keep the dd then get a good header/y setup and put an e-cutout on there and get a stall. thats under 2500. may even be able to swing a ls6 intake. all that stuff is a great start. you'll want all that before you throw a cam in the car.
SOMbitch
11-08-2009, 04:02 PM
Just be fore warned... 11-11.5 is not as easy as some on here make it out to be and once you get there you will quickly learn the stock rear and A4 tranny will not like it one bit......:)
Weight reduction is the best way to pick up speed cause it's usually cheap and saves wear on other parts. You will sacrifice comfort though if it's a DD... There is a weight reduction thread around somewhere that tells you what you save with each mod.
Yes get a GOOD stall but when you start making 11-11.5 power go ahead and get the tranny upgraded so it doesn't grenade and take your new pricey stall with it......
Gordon0652
11-08-2009, 04:50 PM
The Corsa sound note is unlike others, its pure sex. Even borla can not match it.
I sold my old Corsa for 400.00 Cash. I am sure you can find a used Corsa for near the same price.
I will be putting the Corsa 3.5 back on my T/A even after the new motor, the exhaust will most likely drop me 100+rwhp but who needs a lot of power on the street. Removable Y-pipe at the track...
Corsa + LTs + ORY = OMG
SSCAMARO02LS1
11-08-2009, 08:49 PM
much appreciation guys....Def going with the Corsa after some thought -- lifetime warranty and if u only have to do it once then why the F not......
thanks for the input on everything, I think I have a good idea where to start now...
This site freakin kicks ass...I appreciate all advice given, and I know it won't be easy SOMbitch but the challenge will make it even more worthwhile after its done.
Thanks LS1 Crew......SS02LS1
OutlawMedic
11-09-2009, 09:29 AM
I like the sound of all the talk about the Corsa. I bought it and had it sent home. When I rotate back to the real world can't wait to hear it now
