Generation IV Internal Engine - 6.0 build help
bigwilly1878
11-06-2009, 12:23 AM
ok guys, im buildin a 6.0 for my truck, im just wanting everyones input on wat i should use... im going with a stock bottem end heads cam nitrous... i want to have around 525 with nitrous still going for daily driveability.. any experience with setups like this would be awesome.. looking for wat block, heads, intake, cam etc etc etc.. im just looking for ideas... and thanks for all the help
bigwilly1878
11-07-2009, 05:39 PM
ok so apparently no one really wants to help.. the only thing i know is im going to use a lq9 block with arp rod bolts... i dont know of any other precautions i should take with the block... im thinkin of using the l92 heads after someone ports them.... i still dont know what intake to use though
CJ Hungus
11-07-2009, 05:57 PM
Well I would check out the "performance trucks" tab at the top of the page. They might be able to help you out.
NemeSS
11-07-2009, 06:00 PM
use the stock heads with aggressive cam, 230-240 intake duration.
if its a lq9, pull the heads, cut in relieves, mill the heads, gm .051 gasket.
shoot for 10.5-11:1 scr. the ls6 intake or the 90mm tbss intake will more than support 525bhp.
no need for l92 heads or intake in this case.
INTENESS
11-08-2009, 07:01 AM
I would also use good hardware for your setup like arp head bolts or studs if you want the extra clamping force.
cjcullom
11-08-2009, 04:38 PM
The PT tab will get you to guys that run trucks like myself, but I enjoy both sites equally. The main difference you will see is torque vs. horsepower...heavier trucks need more torque to move the mass (6300# in my case) than do lighter vehicles. Check out the build threads and harvest some ideas; No need reinventing the wheel
