Conversions & Hybrids - Setting pinion angle.
BlackTA96
11-06-2009, 12:38 PM
Alright, so I'm about to fab up my transmission crossmember, but i'm concerned with pinon angle. not sure on where the motor/trans needs be set at(angle). Will I need the drive shaft in in order to figure this out?
You guys get what I'm saying?
Anyway the help is much appreicated.
Buckndol
11-06-2009, 03:36 PM
I used a level with a lazer beam. I set the differential to aim just below the tailshaft and set the transmission to aim just above the yoke. There might be a better way but this works for me.
S10xGN
11-06-2009, 09:25 PM
Driveshaft not required. You want complimentary angles. For example, if your tailshaft is 3° down, you want the pinion 3° up. That's ASSuming the pinion won't rotate on acceleration or deceleration.
Russ
Pop N Wood
11-06-2009, 10:18 PM
You want the two shafts to be parallel. In other words draw a straight line out from each shaft and adjust the mount so the lines are always the same distance apart no matter where you measure them.
i made a couple of laser pointers like in the link below. Mount them to each shaft. I then held a piece of lined notebook paper up to the trans laser pointer and marked how far apart the two dots are both up and down and left and right. I then held the paper in front of the laser pointer at the diff and did the same. Then it was just a matter of adjusting the diff and/or trans until the distances were the same front and back.
http://forums.hybridz.org/showthread.php?t=109413
BlackTA96
11-09-2009, 03:39 PM
sound easy enough.
I'll have to try it out.
livefast1
11-09-2009, 05:44 PM
i always set mine up with the pinion -2 so i measure at the face of the crank pulley/ dampener and the face of the pinion gear and set it so the pinion gear is 2 degrees less.
engine l \ rear or engine / l rear hope this helps.
CharlieC
11-09-2009, 08:47 PM
Great explanation on things here....
http://www.hotrodlane.cc/ONLINETECH/drivelineangles.html
Charlie
Mike52
11-09-2009, 11:00 PM
Here is another link with great info on proper pinion angle setting from Inland Empire Driveland. http://www.iedls.com/ptsetup.html
Mike
Petraszewsky
11-09-2009, 11:11 PM
There are a lot of variables that play into pinion/driveline angles...You may want to read til your eyes bleed before you take some of this advice into consideration...Although everyone meant well...
