General Maintenance & Repairs - Misfire and idle problems
afattitude
11-06-2009, 05:49 PM
I have had problems with backfiring at low rpm under load and a slight miss at idle ever since I did the EGR/AIR delete. What should I start looking at? Wires possibly?
2000 Trans Am M6
EGR/AIR delete, Lid, full exhaust w/ LT
+badss+
11-12-2009, 08:05 AM
have you tuned the car at all
afattitude
11-12-2009, 08:16 PM
I just got HPtuners and started to try to remove the EGR and AIR from the PCM. But maybe I didn't do it right?? Other than that not anything major ex. timing tables, spark, fuel etc...
Wesmanw02
11-12-2009, 08:44 PM
Is your Service Engine Soon light on with codes for EGR and AIR??
I'm assuming you used block off plates on the intake and exhaust to close up the ports...
