Fueling & Injection - Help with dual intank pumps and upgraded lines.
pdasterly
11-06-2009, 06:09 PM
I have a 02 camaro. Ordered two walbro GSS340 pumps. Should i get http://www.jegs.com/images/photos/02715118.jpg 3 of these and just run new lines?
koolaid_kid
11-06-2009, 11:24 PM
Have you read the sticky at the top of this section? Most put the "y" in the tank and join them there, then use stock lines from there on.
396375
11-07-2009, 10:13 AM
I agree on the sticky.Well writen.Unless you are making crazy power then the stock lines will work fine.A lot of people use the stock feed line as a return line and run a new #8 feed line.
Good luck.
pdasterly
11-07-2009, 01:14 PM
looking for 1200 rwhp give or take. The pumps will be Y together inside the fuel pump assembly bucket. I want to run two hot wire kits and a hobbs boost switch. I read somewhere that i need a minimum of -10an. I want to run the two pumps together inside the factory fuel bucket. The lines running to the filter, I think i have two options, buy a -12 stainless line or run some aluminum hard line -10 i think with the correct adapters. Aftermarket fuel filter installed and -12 hose to a aftermarket fuel rail with fuel pressure regulator installed after the rails. I will be running 90lb injectors, high impendence
SStolen
11-07-2009, 10:01 PM
You're going to need three of those pumps to put down 1200rwhp. And with that much power, I don't think I would risk that set-up with a basic 'baller on a budget' fuel system. You need to get a real set-up. You have to pay to play and at 1200rwhp, you definitely want to play. If you don't, It'll turn into one of those save money now but pay more later things. Good luck with whatever you decide on.
pdasterly
11-09-2009, 03:05 AM
what would you recommend, i want to keep the stock tank
Nasty N8
11-09-2009, 02:24 PM
You are not going to make 1200rwhp with the stock tank and dual pumps. The dual setup when done correctly is good to about 1000rwhp. More than that you need a big external pump pulling fuel from a sumped tank. Give me a call we have a system to suit your needs. Including a new tank with builtin internal race pump and filters for very high HP street setups. Extremely new so give me a call for some details.
MIGHTYMOUSE
11-19-2009, 07:00 PM
def not gonna fit 1500hp thru that fitting.
id like to see 3 walbros inside the tank tho.
or runner up a walbro and a bosch might sneak in there
