Nitrous Oxide - 427 ls block n20 combo?
View Full Version : 427 ls block n20 combo?
cryer
11-06-2009, 06:30 PM
I have a 427 ls block what crank length and rod length should I build for a good n20 combo? 250 shot one stage
cryer
11-07-2009, 07:58 PM
nobody?
blu byu EH
11-09-2009, 12:25 AM
What size is the bore? If its a 4.125 bore then all you need is 4" crank w/6.125 rods.
JL ws-6
11-09-2009, 11:21 AM
What bore are you going with? Honestly I'd put a 6.1 rod in the car and give yourself some more room (if this is a 4.125 bore/4 inch stroke) for the ring pack above the wrist pin.
Firehawk441
11-09-2009, 06:34 PM
4.130 bore and 4" stroke with a 6.125 rod.
cryer
11-10-2009, 01:45 AM
block is stock bore now ,and perfect
I just dont want to send up with the ring to high.
thanks for the help
ShiznityZ28
11-10-2009, 09:16 AM
3.9 crank and a gorilla piston.... Id take a 402 with a sick nitrous piston over a 427 with a "good" nitorus piston every day...
