Conversions & Hybrids - wire harness
View Full Version : wire harness
dec010974
11-06-2009, 10:14 PM
hello ls1tech fans. i want to know who has info on using, modifying the factory wire harness (DBW) to work with 5.3/4l60e swap into a '87 c10(DBC). any help will be appreciated. i have the old factory harness that came with the motor. i also have a DBC throttle body.
Pocket
11-07-2009, 12:07 AM
Read this
http://www.thirdgen.org/techboard/ltx-lsx/544768-ls1-harness-start-finish.html
Pick up the missing connectors at a JY or wiring company
dec010974
11-12-2009, 01:50 AM
i found some useful info from lt1swap.com in referrence to those who want to make their own wire harness.
juced211s
11-12-2009, 05:45 PM
What year is the motor? Which PCM?
dec010974
11-12-2009, 08:27 PM
hello. im converting a DBW '05 5.3/4l60e to DBC. i have a DBC ecm. here are some photos. also where can i buy a special crimping tool and female terminal pins that mate the harness to the ecm?
juced211s
11-12-2009, 09:00 PM
I will assume you are using a 411 PCM if not let me know. Essentially take three of the wires for the drive by wire and use them for the TPS (Pins C1 8, C1 60, and C2 24) A, B, and C, respectively. C1 is the Blue connector. Then four other wires for the IAC (Pins C2 77, C2 76, C2 78, C2 79) A, B, C, and D, respectively.
Keep in mind there are other changes you have to make to the O2 circuits ect. since you are going from a green/blue pcm to a red/blue. Hope this helps.
dec010974
11-12-2009, 11:57 PM
lt1swap.com gave me the info for the IAC and TPS connections along with the pcm grounds that change between the blue/red connectors and blue/ green connectors. the O2 sensors are diff also. for ease i will use DBC ecm and connection. i need those pins, crimping tool. or maybe i can use some of the wires i removed from the stock harness. thats an idea.
juced211s
11-14-2009, 01:53 PM
Crimping tool is $70, terminals are .50 each.
Remember you have to use gray/white connector O2s if you are going with the Green/blue pcm.
dec010974
11-15-2009, 10:02 PM
juced211s. please, no 187s. just kidding. where can i pick up the crimping tool? also have you created your own harness? if so, fuse block . where did you get them and what items do you send to the fuse block? i can be emailed by pm.thanks
Thealien
11-15-2009, 10:05 PM
interested in the crimper myself
dpd069
11-16-2009, 06:40 PM
waytek
http://order.waytekwire.com/cgi-bin/lansaweb?procfun+wordpr01+webfunc+M37+FUNCPARMS+WE BCMP(S0020):01+WEBID(S0020):01
ls1nova71
11-16-2009, 08:36 PM
LT1swap.com will almost walk you through the process of modifying your own harness. There is alot to read on that site, just take your time reading it and you should be able to do it yourself.
As for a wiring block, this is from LT1swap, http://www.lt1swap.com/fuseblock_obd2port.html
juced211s
11-16-2009, 09:38 PM
The blocks and crimpers can be purchased through Mouser as well as Waytek as dpd stated above. We just acquired a 68 C10 that we are going to put a DBW 5.3 in. I will update as progress permits.
Thealien
11-16-2009, 10:15 PM
waytek
Which crimper?
juced211s
11-17-2009, 12:14 PM
The one I use is a 12125080. I dont see it on the waytek site but I would call and ask. Mouser has it for $77.00. This is for PCM terminals only.
dec010974
11-22-2009, 08:46 PM
the wire harness from DBW to DBC is coming alone just fine. the final peices of the puzzle came today. what do i do with these two holes? the intake is a DBW but this extra port from the DBC throttle body has me baffled. look at pics. i know for for sure that one port leads to the valve cover.
busta9876
11-22-2009, 10:43 PM
Plug one, then hook up the line to the other one. Does not really matter.
These both allow air to be drawn from in front of the throttle blade, into the right valve cover, down into the motor, up into left valve cover, through PCV valve, and into the intake manifold plenum.
Some of the DBW throttle bodies did not have that tube, so they made the passage in the intake. Some intakes that area is solid, some have the nipple.
