Fueling & Injection - Weldon fuel pump?
DeanJ
11-07-2009, 08:48 AM
Can I purchase a Weldon 600 from a sponseron here? Also, can it be installed in tank? Thanks , Dean.
Nasty N8
11-09-2009, 02:26 PM
No it can not be installed intank Weldon does not rec. it. I do have intank options give me a call.
Jim Craig
11-09-2009, 03:24 PM
It is not that it will not operate correctly, it is just that Weldon believes why put it in the tank if there is room on the outside of the tank to mount. IF it were to stop working (as is the case with any electric fuel pump) then its certainly easier to service the pump when it is outside of the fuel tank than if it were "stashed" down inside.
The 600-A & 1100-A draw fuel extremely well as long as the pick up tube is always submerged in fuel -- as it is the case with all of their pumps when mounted on the outside of the tank or cell.
Nasty N8
11-09-2009, 04:59 PM
Yes we use alot of Weldon pumps for external they are very good pumps. Will be easy to mount with our new intank setup it will have a whole module with Pump, Voltage controler, filters and wiring all mounted (and easily removable) inside the fuel tank to help keep the pump cool and quiet. We are working on fuel tank systems up to 2500HP. Whole setup will fit and function just as factory.
