Stereo & Electronics - battery relocation?
02b4ccamaro
11-07-2009, 11:53 AM
i want to relocate my battery to the trunk, and i dont want to cut up the factory wiring. just want to see any pic or get some ideas on how i can do it.
Ws6kid.
11-07-2009, 12:09 PM
i would like to do the same.!
and out a small fuel cel in where the battery used to be for some N20 :P
blackbyrd
11-07-2009, 12:10 PM
several companies make a kit bmr is one of them
Ws6kid.
11-07-2009, 12:16 PM
yea i know they make the bracket to relocate the battery but what about the lines? i would like to see some one make a write up about it or things i should look out for in relocating the battery
squee
11-07-2009, 02:02 PM
There is a guy on here who makes a block to do it. All you do is screw the stock cables to the block and run a wire to the back. Couldn't be more simple really...
99Bluz28
11-07-2009, 03:21 PM
This should get you going.
http://www.ls1tech.com/forums/drag-racing-tech/994972-help-battery-relocation.html
http://www.ls1tech.com/forums/paint-body-work/982993-battery-relocation.html
RAMPANT
11-07-2009, 03:28 PM
I just thought I would give you guys an option. I planned the same thing. I bought all the parts seperately since I wanted mine on the drivers side and the bottle on the passengers side. I then weighed all the cable, brackets and mounts. It came to 23lbs, WTF. Add 23lbs to the car so I can move 34? I autocross and take it to the strip so front weight and total weight matter. So I looked into a light weight set up. I went with the 15lb Braille battery. With the bracket it came to 17lbs, for a savings of 17lbs and 17lbs less on the nose. I do have a bigger stereo in the car and it seems to work just fine. Just food for thought.
Sorry, I need better pics of it, but you get the idea.
http://usera.imagecave.com/rampant3/updates/upload2.JPG
http://www.2002firehawk-c26.net/Addison/Addison57.JPG
