98 ls1 s10
98 ls1 s10
Year: 1998
Make: Chevrolet
Model: S-10
Price: $5500
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): KS
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
5.3 block bored to 346 ci
stock ls1 pistons, rods, and crank
arp rod bolts
stock 5.3 heads ported and polished also milled to increase compression
compression ratio 10.8:1
rollmaster double roller timing chain
02 Z06 cam and valvespring
Manley hardened pushrods
GMPP single performance carbureted intake manifold
Holley 670 street avenger carb with vacuum secondaries and electric choke
MSD 6010 programmable ignition box with 2 step and nitrous retard capability
Sanderson 1 5/8 shorty headers with SCE copper gaskets
LS2 corvette oil pan, windage tray, pickup, and dipstick
Trans:
Lokar flexible dipstick tube
Edge racing converters custom street strip converter 3100-3300 stall 2.2 str ratio set up with large bore pump to increae highway coupling
Th-400 transmission street strip prepped for up to 750hp
Trans-go level 3 shift kit
Adjustable shift modulator
Kolene steels and Alto red clutches with extra clutches and steels added to intermediate and direct packs
32 element roller sprag and direct drum from 4180 Trans
direct clutches priority fed by valvebody
deep tuck aluminum pan for added cooling
LPW trans coller
B&M megashifter
Suspension:
Cal Trac traction bars
QA1 fully adjustable coil-ver front suspension
lowered rear leaf springs with Nitro drop Shocks
Larger diameter sway bars
rear mounted battery
Interior:
upgraded Sony speakers all around
JVC head unit
Fully custom AutoMeter gauge display
Brand new carpet recently put in
Rear End:
8.5 inch swapped in w/ drum brakes 3.73 gears and a PowerTrax Locker with brand new springs
Braided brake lines
Upgraded drilled and slotted disk brakes with caprice calipers
Need truck gone for financial reasons. Not interested in trades. Truck is Located in Manhattan, KS. Fuel gauge doesn't work it needs to be re-callibrated for the year of truck its in. Does not have A/C either, have everything but the compressor, never installed it mainly cause i didn't care to put have it. PM me if interested will listen to offers just don't try to lowball me. I know how much this truck is worth and i know how much i can get out of it. If seriously interested email me at pudge@ksu.edu and i will send pics to you. I will be honest probably won't check this site nearly as often as my email. If not local pickup the shipping will need to be paid for and set up by the buy. I have a flexible schedule i can deliver truck to delivery truck when ever.
pics: http://s816.photobucket.com/albums/zz83/pudge600/
