Stereo & Electronics - Looking for install kits
Fierce-LS1
02-13-2004, 11:13 PM
Just bought a din head unit. Where's the best place to find a good metra or best kit unit. Do they still have the ones with a little opening on the bottom so you can store things under the DIN headunit ??
This is for a 2002 Trans Am.
maddboost
02-14-2004, 01:49 PM
The metra kit that they make for the TA doesnt have a pocket its a flat panel. Kit will run you about $15.00 you also will need a wiring harness which will be $15.00, and a antena adaptor wich will run you $10.00.
ls1camaross
02-14-2004, 05:53 PM
You can normally pick up a Metra kit at any local places. I picked up a dash kit and an attenna adapter for just a little bit over 30 bucks.
D Rock
02-15-2004, 11:11 PM
Which kit is the one that comes out a little bit, doesn't fit back into the stock peice, but comes with a new trim peice.
maddboost
02-15-2004, 11:20 PM
:huh:
LS1Baron
02-16-2004, 08:18 AM
The Metra kit you're looking for is available as part number 99-4544. That is the kit with the pocket.
