Eugenio_SS
10-28-2004, 08:23 AM
Hi all,
I'm pissed @ my Monsoon system and its speakers... now the left ones are dead, and I feel like ripping the whole thing out and see how it'll survive the fall from my balcony (11th floor).
if you guys were to build a system, with great components... what would it be ?
I know nothing about this... and I want to do it only once, and do it right.
I want great sound quality... and I know quality has a price.
For now, no sub, but later, I can always get a sub if I ever want to... I don't like the boum-boum, plus I have a vert, and the spare tire location is already used for nitrous.
Which brand speakers are the best for music quality ? (I heard Boston are good)
Are Alpine HU good units ? (I've always had a weakness towards Alpine)
Which brand of amp is good for low distortion ?
I'm willing to ditch around 2000-2500$.
Anyways... please help me.
I'm thinking on going with the following... and would like to get your opinion on it... if it'll make a good system.
OK, reading a bit, I'm getting to like the following from what I read... but for the little I know, I need your help.
Amp:
Eclipse PA5532 (http://www.eclipse-web.com/products/amp/amp.html#PA5532)
http://www.eclipse-web.com/products/amp/images/pa5532_img.jpg
125W × 4 Channel + 460W × 1 Channel Max. Power Output at 2 Stereo
70W × 4 Channel + 280W × 1 Channel 0.1% THD at 2 Stereo, 20– 20,000Hz@13.8V (RMS Continuous Power)
50W × 4 Channel + 200W × 1 Channel 0.1% THD at 4W Stereo, 20– 20,000Hz@13.8V (RMS Continuous Power)
ChannelFlex Crossover
Adjustable High-Pass Crossover (12dB/octave, 50–200Hz) for Front & 120Hz (Fix) for Rear Independently
Adjustable Low-Pass Crossover (12dB/octave, 50–200Hz)
Free-Flow Signal Circuit
Double-Sided PCB
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOSFET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
Efficient Cooling with Low-Profile Heatsink
Multi-Mode Configuration
Stereo/Mono Switch
2 Stable Design
$400
Speakers (front):
Boston Pro60 (http://www.bostonacoustics.com/ca_product.asp?ProductID=296&CategoryID=14)
http://www.bostonacoustics.com/images/2x2/Pro60.JPG
6½" copolymer cone woofer with neodymium magnet 1½-inch voice coil
RadiaVent® cooling and Twinstage™ heat sink for increased power handling
Cast aluminum woofer basket
1" Type-M2 anodized alloy dome tweeter with slim AMD™
Separable and dockable crossovers
VariMount™ adapter rings allow for fast installation
Axis-, flush-, and angle-mount tweeter mounting kit
$600
Speakers (rear):
Boston Pro50 (http://www.bostonacoustics.com/ca_product.asp?ProductID=297&CategoryID=14)
http://www.bostonacoustics.com/images/2x2/Pro50.JPG
5¼" copolymer cone woofer with neodymium magnet 1½-inch voice coil
$600
Still undecided on HU... some Alpine.
which HU you think I should use ?
CDA-9835 (http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=CDA-9835&p_category=10&p_subcategory=20&p_main=10):
http://iweb.alpine-usa.com/img/asb/cda-9835.gif
CDA-9833 (http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=CDA-9833&p_category=10&p_subcategory=20&p_main=10):
http://iweb.alpine-usa.com/img/asb/cda-9833.gif
CDA-9831 (http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=CDA-9831&p_category=10&p_subcategory=20&p_main=10):
http://iweb.alpine-usa.com/img/asb/cda-9831.gif
CDA-9820XM (http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=CDA-9820XM&p_category=10&p_subcategory=20&p_main=10) (might be too flashy):
http://iweb.alpine-usa.com/img/asb/cda-9820xm.gif
CDA-9827 (http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=CDA-9827&p_category=10&p_subcategory=20&p_main=10):
http://iweb.alpine-usa.com/img/asb/cda-9827.gif
since I want good quality, I figure the best place to put the $ is on the speakers, provided a good HU and amp is there.
So what you guys think ?
Also, which is better, the Boston Pro60 and Pro50 series, or the MB-Quart QSD-216 and QSD-213 ?
the price is pretty much the same.
Thanks for all those who reply. :)
Amp:
Double-Sided PCB
Stereo/Mono Switch
2 Stable Design
$400
Speakers (front):
$600
Speakers (rear):
$600
