Northwest Members - Paging Mark
View Full Version : Paging Mark
Steve Goodwin
11-22-2004, 10:53 AM
Mark,
I read a post regarding install the pulley that said heat it up to 200 degrees for 1/2 hour put on some oven mitts and it'll slip right on.
I stop by Tacoma screw and see about a longer crank bolt.
WAHUSKER
11-22-2004, 02:11 PM
Now that sounds like a good trick....I'll bet it works too. I still want a 1" longer bolt on-hand just in case. You get it & I'll pay for it.....since I want it when we're done.
And I now have the pinout for the PCM connector. So I need to check some voltages & if they are OK, then I'll go back to HP Tuner & ask for help.
