Stereo & Electronics - bypassing monsoon amp?
View Full Version : bypassing monsoon amp?
Onyx LS1
12-27-2004, 05:36 PM
I am installing a new head unit and speakers and i pulled out all of the monsoon stuff. I want to use the factory wires. my question is do i just connect the speaker inputs to the outputs from the monsoon amp acording to this chart...
http://www.houston-f-body.org/tech/monsoon/AmpCamaro.htm
Should I ignore the subwoofer wires??
Thanks, Justin
wickedwarlock
12-29-2004, 01:02 PM
Thanks, Justin
You should wire it according to the chart if you are using the factory sub and amp.
if you are adding in your own subs and amp later, than I wouldn't wire them up.
