Stereo & Electronics - 100w Headlight Bulbs - What Size Wire?
InfiniteReality
12-28-2004, 04:19 PM
Fixing to install some 100w headlight bulbs in my aftermarket headlight housings on my car. I know I have to use a relay as to now fry the wires. What size would be suffient enough for each light? 12 or 16 gauge?
Thanks!!
InfiniteReality
12-29-2004, 01:00 PM
I used 12ga wire and no heating up of the wire for the 20 minutes they were on while I was testing them. Just a FYI for anyone searching for something similar.
InfiniteReality
12-29-2004, 01:01 PM
Oh yeah, I did calculate the wire size and according to NEC I could have used 14 or 16 (can't remember) gauge wire to run 200 watts of lighting power.
wickedwarlock
12-29-2004, 01:20 PM
also adjust the wire size for it's distance. 14 guage should work but 12 wouldn't hurt either, especiall if you decide later to add more lighting. :)
InfiniteReality
12-30-2004, 01:31 PM
I ran 12ga from battery to relay and 12ga to each light from relay. I over did it to the lights and ever decided to go with high wattage ones and would require more than 12ga to each light I can just upgrade the wire to the battery.
I ran the 100w in their for 2 days. Took them out cause the beam cutoff was all distorted with them. I bought cheap bulbs and paid the price. The silver painted tips was flaking off. :( Oh well, live and learn! The 70w ones I had (didn't know this till I pulled them and they ran off stock wiring for several months) a better color temp and seemed to be a bit brighter with the new wiring. Guess I gained a little out of the whole thing. :)
