Manual Transmission - Good grief, spec stage 3, 3i now the i is f...
DVST8OR
12-29-2004, 02:36 PM
What does it all mean!? :jest:
After searching I found people saying the 3i is smoother than the the regular stage 3. Others say it is worse. Now the f has replaced the i. Is there any consistancy with all of these? Is the 3i or f smoother than the regular stage 3? Is it still an x-pad if you get the 3f?
Cyborg
12-29-2004, 02:41 PM
The 3I and F are stronger than the 3. The 3F is not an x pad.
DVST8OR
12-29-2004, 04:39 PM
Does stronger mean that it is going to be less driveable? i.e. more chatter, less streetable, etc?
Cyborg
12-30-2004, 08:46 AM
3I's chatter during break-in. My car is a daily driver and after break-in, drove like stock. My whole crew uses 3I's except for the really high (600+) HP guys and we have great experience with them. I know griffz28350 put in a 3F a month or 2 ago and he might be able to comment on it. I'm not sure how many miles he's put on though given the weather here.
JeffT
12-30-2004, 09:10 AM
no need to worry about the 3i since it has been replaced with the 3F. You either get the standard stage 3 x-pad or the full faced disc 3F. I noticed no difference in driveabilty between the stage 3 and 3F.
Cyborg
12-30-2004, 09:35 AM
Thanks. We know this. I was just answering his drive ability question. :)
ChevyWeatherman
12-30-2004, 11:25 AM
I talked to a SPEC rep at the PRI show and he showed me a 3F disk. He said the main reason for the change to a full face disk (from the 3I) was to reduce chatter and increase driveability.
Steve Burger
12-30-2004, 12:07 PM
I just installed the 4F and it does drive better than the 3X.
LSs1Power
12-30-2004, 02:07 PM
which one holds more power?
Steve Burger
12-30-2004, 02:31 PM
3F and 4F hold the same power I think. The difference id that the 3F is a sprung hub and the 3F is solid. The Solid hub is better for drag racing. That's why I went that way.
Slowhawk
12-30-2004, 08:38 PM
I like the 3F over the 3I.Alot less chatter,more drivable.
MIGHTYMOUSE
01-02-2005, 10:39 PM
hmm.. new stuff all the time
i finally retired my s4 ceramic for a s4 iron. both never have slipped on me yet. i have no idea what an F is but a full disk is surprising
LSs1Power
01-03-2005, 12:29 AM
How does the S4 iron feels compared to the ceramic?
MIGHTYMOUSE
01-03-2005, 12:47 AM
pretty similar so far.. from what i am told it is a softer hit at the dragstrip.. better for powershifting and big rpm dumps.. will see.
