Stereo & Electronics - Custom Sub Box Help
View Full Version : Custom Sub Box Help
DZBIRD
01-03-2005, 12:20 PM
I am looking for any pictures or suggestions for a (custom) sub box that will fit in the flat "cargo" space under my hatch. I need to keep my truck space open for future bottled surprises :devil:
Can anyone help me out with pics or links :confused:
liquify33
01-03-2005, 02:24 PM
Check out the Millhouse boxes at www.subthump.com
DZBIRD
01-03-2005, 04:07 PM
Anything that fits in the flat hatch area ??? With my future plans the trunk needs to stay open, even the spot where they put the stealth boxes...
liquify33
01-03-2005, 06:16 PM
Are you talking about the flat area behind the back seats, or the very bottom where the t-top holders are? If it's the flat part behind the back seats, the millhouse will fold up there like the stock divider does.
Here's a pic folded back (http://www.subthump.com/images/camaro/milhouse/chevymilhouse%20up.jpg)
Here's one folded down (http://www.subthump.com/images/camaro/milhouse/chevymilhouse%20down.jpg)
If you'll never put it down, you can put about anything back there, just be careful how you secure stuff as the gas tank is under there.
DZBIRD
01-04-2005, 10:41 AM
The flat spot behind the seats. I want it to look like how the millhouse box when folded back.....
badaSS346
01-06-2005, 01:30 PM
I cant remember who make it but 6th Ave has a box that is the perfect size for the flat area behind the seats. Im not liking the fact that the millhouse box is not "stable" and held down. Besides, the 6th Ave on will he a hell of alot easier to take out at the track.
ws6-speed
01-06-2005, 04:31 PM
Just build a box that'll fit there. It's easy enough to do. You know how much volume you need, you know the area available, so it's just a matter of calculating the height. To secure it down, first mount some mdf to the back hatch area under the carpet, then use wood screws, but be careful because the gas tank is back there.
DZBIRD
01-10-2005, 11:34 AM
That's what I'm planning on doing but I want it to look good, not just a box. I want a custom look, not something anyone can buy at a local stereo store. I'm looking for ideas or pics to get my design process going.....
ws6-speed
01-10-2005, 11:53 AM
If you want something custom that looks good, and not just a box, then fiberglass is your friend. Learn how to use fiberglass and you can create a great looking box for the back. Here a couple images to get you started:
http://www.fbodyaudio.com/albums/album01/aac.jpg
http://www.fbodyaudio.com/albums/album03/dscf0003_1.jpg
http://www.fbodyaudio.com/albums/blknite01/aca.sized.jpg
DZBIRD
01-11-2005, 11:12 AM
That's kinda what I'm looking for...I'm looking for a custom look without using fiberglass but haven't had much luck. It might be impossible to do that without using fibergalss to match the curves. Any suggestions ????
ws6-speed
01-11-2005, 11:34 AM
You can't match the curves without using fiberglass, at least not easily. You can use very thin strips of wood and wet them, then bend them in elaborate vices to get curves, but that is ridiculously difficult. I would strongly suggest you look into fiberglass. It's really pretty easy to do. Check out the tech section at www.fbodyaudio.com for some fiberglass tutorials.
DZBIRD
01-11-2005, 01:18 PM
I will look into that, thanks for all the info and advice :thumb:
ws6-speed
01-11-2005, 01:41 PM
No problem!
KrazyDan
01-11-2005, 03:01 PM
I have a Q logic box. Look them up. it will match your car perfectly. I think crutchfield sells them.
sexyvic1
01-24-2005, 03:13 PM
there are boards and custom boxes made just for the rear dip in those cars, just do a basic search or go on ebay, there are alot of different styles. goodluck
DZBIRD
02-03-2005, 12:51 PM
Do the boxes sit behind the rear seats or in the well where the T-tops are stored??? I'm looking for a box to sit behind the rear seats, on that flat spot
sexyvic1
02-03-2005, 03:09 PM
oh sorry, the only thing i saw goes in and over the well, i haven't seen anything in the flat area.
your best bet is probably build something or look into a pick-up truck box, they will lay flat enough were it won't be in your view from the rear view mirror and they are angled too so it would look nice .
ArcticZ28
02-03-2005, 03:26 PM
I have a box that fits perfectly in the flat part behind the rear seats if you're looking to buy one. It's a Q-Logic that fits 2 10's (there's actually a small picture of it in my sig). I had my Alpine Type-R's in there before I transferred to a custom Q-Logic that fits in the t-top well. PM me if you're interested.
KrazyDan
02-03-2005, 09:48 PM
If you get something to go on the flat spot, you wont be able to look though your back window.
ArcticZ28
02-04-2005, 02:13 AM
Actually, my box only cut off about 1/8 (1/4 at the most) of my vision out the back. It is positioned so that in the rear view mirror it only sits slightly higher than an SS/RS sits looking straight out the back.... just fyi
Richiec77
02-04-2005, 02:46 AM
In your pics it looks like it sits high.
Learn to use fiberglass. It's really not that hard. I used to think it was exotic until My friend showed my how to mix resin. That is about the only hard part to it. (unless you don't wear a breathe and pass out from the fumes. Then the floor is the hardest part.)
ncSSu
02-04-2005, 09:20 AM
I made a custom box to fit right behind the seats, it fills up that area perfectly and sits flush with the rear seat, its nothing special and I am hoping to do something better at somet point but it works
Richiec77
02-04-2005, 09:30 AM
I was thinking that in that area a single 12" would work nicely. The cabin gain of F-bodies is pretty good. (most Hatchbacks are). You could make a box/amp rack all at once. You would only need to use Fiber glass to shape the curves over the back side panel. The rest can be accomplished by MDF. Just Just a couple anles, Belt or mouse sand them into shape. Are you going to paint it, vinyl it or just carpet it. If you Paint it will take a lot more work to smooth it out. Vinly would take just a little more work than carpeting and would look nice if dyed to match your interior. Just goto a good Paint shop and they should be able to mix some vinyl dye(not Paint), color matched and spray it for you for cheap. About $50-75 would be fair. Good luck man. Custom work really isn't hard when You learn how to handle Fiberglass and Bondo.
