Corvette Performance - Low oil pressure?
Blown Interceptor
01-15-2005, 01:36 PM
Just noticed after I replaced the sending unit and installing an LS6 intake. The oil pressure is around 20 at idle and cruising it is around 30-35psi. Is that normal? Or is it too low? A buddy of mine with a 99 Camaro, says it is too low, his is just under 40psi at idle.
Thanks,
Jason
badjuju342
01-15-2005, 01:57 PM
You might want to think about a ported LS6 oil pump. It's not that expensive (around 150.00) and is a helluva lot cheaper than a new engine! The oil pressure isn't dangerously low but it's not that great , either.
Blown Interceptor
01-15-2005, 02:32 PM
Thanks...the pump is cheap, but I'm sure the labor won't be.
2MuchRiceMakesMeSick
01-15-2005, 08:15 PM
Its not that bad to replace the pump. Heres a step by step for an fbody but its pretty much the same.
Oil Pump Install (http://www.ls1howto.com/index.php?article=4)
Slowhawk
01-16-2005, 10:44 AM
It's low but not too low.Whats the pressure at 5000rpm? I like 35-40psi at 1800rpm or so and 60-70psi at 5000+rpm.
