Small Block & Big Block Chevy Specific - which one is better hand ported or cnc ported?
eric01ss
01-19-2005, 08:05 PM
ehy guys which one is better
and which one will flow better
hondo
01-19-2005, 08:14 PM
it doesnt matter, it depends on who designed the cnc program or who is porting the heads by hand.....
just pick a set of heads.your car will never "haul balls" if you dont pick some heads and get them on there.
mzoomora
01-19-2005, 08:50 PM
The cnc will give you more even flow across all cylinders, so i would pic those.
CTSV05
01-19-2005, 09:54 PM
69,
It really is a tossup, a shitty porter can make the best head flow nothing, and a good porter can make a shit head great.
But as already stated, a cnc head is more consistent. If you have access to someone of exceptional talent, use them, I do my own under the eye of a very talented porter.
If I couldn't, I would opt for a cnc head.
Aren't you spraying this motor? If so then every cfm will not break your performance, not as much as the wrong converter, gear, system, and mostly the cam.
