Small Block & Big Block Chevy Specific - Help On 427sbc Project
80vette
01-29-2005, 05:00 PM
Iv got a 400 gm block want 600 hp 550 tq This is what i have= 400gmblock 4 bolt splayed maincaps ordering the world rotating kit=427 . Have hookers all msd air gap intake frome edelbrock want to know what cam heads and all . Will have spray dont want to go solid roller and yes streetable. Thx for all the help u can give :drive:
1QuickT-A
01-29-2005, 08:44 PM
About the only way you will get 600hp is gonna be with a solid roller cam. Unless you mean 600/550 with the spray. If I were you I would get a set of AFR 227's fully CNC'd from AFR or some Dart Pro 1 230's.. And I'd junk that Air Gap for a Victor Jr or Super Victor.
PRAY HRD
01-29-2005, 09:40 PM
i would disagree completely. 600hp and pump gas is definately doable with the right amount of air in/ air out....head/cam setup, with a hyd. roller cam. 427ci is big, and that's only 1.4hp/ci. that should be easy enough so long as, like i said, you have the right head cam pkg. i will agree with the Victor Jr. that shouldn't be a restriction for that kind of power. i'm not saying it's easy, just talk to a pro shop and ask their recommendation.
later,
Dave
80vette
01-29-2005, 09:52 PM
Thanks guys and no not with the juice
Villain281H
01-29-2005, 11:59 PM
could be done without a solid roller, but either hydraulic roller or solid cam would have to be choice, plus heads are the key. Another in agreement for the victor jr, possibly even a super victor jr. Go with a 750 hp carb at least. I'd consider calling cam and/or comp cams deirectly for their recommendation on the cam selection, or as stated above you could always get the advice from a shop with experience with combos similar to what you'd like. Make sure you have the info on what gearing, trans, convertor or clutch, and weight of the car will be.
Derek
CTSV05
01-30-2005, 12:30 AM
Good Advice.
A solid roller should not be a problem. Personally, I think a hyd. roller may come up short in the upper rpm range.
68maro
01-30-2005, 06:04 AM
and a 750 won't cut it. go dominator.
Villain281H
01-30-2005, 11:21 AM
we've got a shop car putting out about 550 hp with a 750 hp, not just a standard 750 carb. Dominator could help, but might be a little overkill, IMHO.
TwoFast4Lv
01-30-2005, 11:40 AM
one of the guys here bought a Shaffirof 434 last year.
He wound up with a dominator to pick up 3/10ths
80vette
01-30-2005, 03:00 PM
thanks guys but i would like to go with the motowns 220s crane 558/558 240/248 at .050 it dont say the lsa this is from summit oyeah a victorjr intake and a demon crn-119651 pt number for the cam ----plz tell me what u think and what it will produce
80vette
01-30-2005, 03:04 PM
o yeah is there any factor for needing 3inch exhaust
CTSV05
01-30-2005, 06:04 PM
That cam won't get your 6 hundo!!!
eric01ss
01-30-2005, 08:15 PM
just put a little spray on it and there u go man
Villain281H
01-31-2005, 08:05 AM
a 600 hp motor would need at least 3 inch exhaust, if not possibly 3-1/2". Hell I put 3 inch exhaust on a 400 hp motor in my nova and picked up a tenth over a similar mandrel bent system, but in 2-1/2" diameter. I agree, that cam is probably not enough rpm range to get you to 600 hp.
slow trap
02-01-2005, 10:50 PM
why not solid roller?if you haven't purchased heads allready the ones set up for a hefty sr isn't much higher.i can't remember how big of a hr you can get i'd go atleast upper 250s @.050 & .600+ i'd say for 600-650 hp=230 pro 1s or afr 227s,motown 220s may get you there. you need a healthy cam =.264/268 @.050 .660/.630 lift or similar SR .call comp or other cam manufacturers.
slow trap
02-01-2005, 10:51 PM
oh yeah i can vouch for atleast dual 3 inch.
1QuickT-A
02-01-2005, 11:46 PM
So, like I said.. in order to obtain 600+hp then you will "more than likely" want to go with a solid roller camshaft. And yes, call Comp Cams and get a custom grind cam that is setup solely for the setup you are running. Cam would probably be around 260-280 duration and .650-.670 lift. Just depends on the head you go with. And yes, Victor Jr or Super Vic is the only way to go just really depends on the heads & camshaft you end up with.. And you will need 3in exhaust for sure.. Bigger would be better but 3in will work ok. I would think that the Dart 230's or AFR 227's would be the way to go. I don't think the Motown 220's are enough head for an engine that size.
PRAY HRD
02-02-2005, 12:13 AM
dual 3" should be more than enough for a non forced induction motor. heck, it's what i will be using to attempt my TT 1200hp pump gas setup. it's been done before.
Dave
80vette
02-02-2005, 05:10 PM
thx guys u changed my mind but to add i wont have a stall (not by choice)
80vette
02-02-2005, 05:22 PM
what about a set of brodix track 2s 208 in and 202 out thats all i know but got a very good deal 900 for both
pwr2w8
02-02-2005, 05:36 PM
Hot Rod did a test a while ago and found 3" exhaust makes a difference even on a mild lower 500hp motor.
CTSV05
02-02-2005, 11:32 PM
Those heads will get you your 600 with the right cam and some compression. Oh, and a real carb, like an 800 or more.
terr1bleone
02-09-2005, 06:23 PM
if your looking for any of these parts i have a victor jr port matched 1206, and a quickfuel 750 hp (aprox 830 cfm)anidized red proform body all the good stuff pm if intrested
80vette
02-09-2005, 10:01 PM
whuts up dude ah yeah how much???
terr1bleone
02-09-2005, 10:18 PM
was that to me? if so id like to get about $225 o.b.o. for the Victor Jr intake with fresh port match from Rizzuti small blocks to 1206 gasket, chrome t-stat housing, 3" carb studs, and needed plugs mabye 15 mins run time, about a year old in total. and $500 o.b.o. Quick Fuel 750hp, billet baseplate, billet adjustable metering blocks, nozzle squirters, and braided bg fuel inlet log with all fittings needed. have pics too. very good carb cost about 800 new, has low miles on it and new gaskets all around. or trade for sbc stuff?
and pm> i dont want to ruin his thread with my shit.
80vette
02-09-2005, 10:49 PM
for what do u wwant as in sbc sh!t
80vette
02-09-2005, 10:52 PM
sorry dude not to sur with this hole pm stuff just started to this forum.SORRY
terr1bleone
02-09-2005, 11:04 PM
what do you have? looking for something of at least equal value, heads mabye? or cash works too.
terr1bleone
02-09-2005, 11:21 PM
seen these earlier in the posts, they yours? trade you for those if they are complete, valves, springs, retainers... you know. mabye even a little cash if you want, but the carb was 800 to build and it is basicly brand new.
72chevy2
02-09-2005, 11:49 PM
pm me the specs on those heads if you could..... and about any other various sbc stuff you have for sale
