Small Block & Big Block Chevy Specific - $300, what should i buy for my SBC?
Bowtiered
01-30-2005, 06:53 PM
what'll give me the best power gain, in your opinion?
6Al box and kit (coil, box, wires)
roller rockers
torker II intake
KB race pistons (but idk if they sell them for non bored engines)
right now i have edelbrock performer intake, performer carb, and 282/282 (.465/.465) sum 1104 cam this is running low compression in a GM crate 350, so i'm thinking pistons will probably do me the best?
eric01ss
01-30-2005, 08:03 PM
i would say pistons or change intake
Keith
01-30-2005, 08:59 PM
What heads do you have on there now?
Do you have room for a Performer RPM AirGap?
1QuickT-A
01-30-2005, 09:20 PM
what about a better set of heads.. like some Vortec's or something.
Bowtiered
01-30-2005, 11:25 PM
kenny duttweiler 23* trick flows will be on the way shortly, but not with that $300 it was somewhat of a windfall
distortion_69
01-31-2005, 12:27 AM
1.6 Roller Rockers
Pistons could possibly cost more than $300 if you need more than a self-done ghetto hone. I would just use the heads to raise compression with smaller chambers, possibly mill them and buy 1.6 roller rockers.
Peace,
Josh
prhotrod
01-31-2005, 01:30 AM
nitrous :)
Villain281H
01-31-2005, 08:08 AM
I'll agree with the intake swap and/or roller rocker to bump up the cam range a few hundred rpm. But the best bang for the buck is spray! Find a used nos powershot or edelbrock kit and enjoy the extra ponies. :D
Derek
CTSV05
01-31-2005, 08:27 AM
Stay away from a single plane with that small of a cam.
Think TORQUE!! I would go with 1.6 rockers, this will help you to take advantage of the heads.
Is this for the Blazer? if so nitrous is not going to give you the everyday improvement in driveability, it has its place, but who wants to drive a turd when not spraying?
Camaro Junkie
01-31-2005, 08:47 AM
Beer ?
Wnts2Go10O
01-31-2005, 01:41 PM
Beer ?
thats a lot of beer.
i say flat tops or rockers
slow trap
01-31-2005, 04:50 PM
well the preformer rpm air gap is proven time and time again to pick up 5-10 hp & tq and only 200 bucks. 150 more for proform 1.6 rrs.but take it from me,don't use cheap proforms on a medium sized solid roller,they should be fine with that small of a cam.should be close to 20 hp total.
pwr2w8
01-31-2005, 05:05 PM
I say if you are going to upgrade the other parts in the future then you should go with the ignition. With any daily driver type you would probably be better off by reinforcing what you have.
The cam and compression are matched so I wouldn't do the pistons, and like stated above you can raise compression when you swap the heads(and hopefully cam too).
Just my 2 cents.
