Small Block & Big Block Chevy Specific - What do SBC and BBC longblocks weigh? (Iron block and aluminum heads)
SPANKY LS1
01-31-2005, 08:08 PM
What do the following combos weigh, in longblock form approximately?
A. Iron block SBC with aluminum heads?
B. Iron block BBC with aluminum heads?
Shawn
crow2
02-01-2005, 06:45 PM
Shawn The small block engine with alum.heads with a iron block dressed out without the carb would weigh around 475lbs.
The big block,with alum heads and a iron block dressed out also but with a carb stuck on it would weigh around 700lbs.
Both are also figured with waterpumps and balancers,dist!
Hope that helps ya! :)
