Small Block & Big Block Chevy Specific - what times do you think i'll run??
slow6.0
01-31-2005, 09:27 PM
i have an 85 shortbed 2wd chevy pickup and i am building a .030 over 454 with 11.5 to 1 comp. with probally a comp 292 cam (not quite sure on that yet) a set of ported 781 heads, torker 2 intake and an 850 holley vacum secondary carb and probally a 250 shot of n20. the truck is going to be on a diet, i am guessing some where around 3600lbs range and it will have the Cal-track traction bars and slick so it should pull decent 60ft. times. So what does everyone think it will run. I am hoping mid 11's on the spray???
eric01ss
01-31-2005, 09:39 PM
maybe low 11's
eric01ss
also i would cahnge to a vic jr single plane intake
slow6.0
01-31-2005, 09:45 PM
well se what it runs with the torker on it and probly just the 200 jets for now but if it gets in the low 11's the i will defenitly change manifolds and bump the jetting up and try for a 10.99 :drive:
eric01ss
01-31-2005, 10:01 PM
sounds cool man
i'm putting a 420 in my 88
Villain281H
01-31-2005, 10:48 PM
I'd say mid 11s should happen, but always hard to guess times on a combo on paper unless someone else has run the exact one or something VERY close to it. good luck!
Derek
CTSV05
01-31-2005, 11:55 PM
Yeah, I have been disappointed before too.
It should be torquey, But not being familiar with the heads capabilities its hard to say.
You'll prolly be close.
1QuickT-A
01-31-2005, 11:57 PM
i would definately go with a single plane intake if i were you.. single planes seem to work better with nitrous in most applications.
slow6.0
02-01-2005, 06:17 PM
thats the thing that is confusing me i thought the torker was a dual plane as well but the one i have is a single plane with longer runners than usual, plus it already has the bosses to set up a fogger system :eek2:
