Small Block & Big Block Chevy Specific - Specs of 305
View Full Version : Specs of 305
02WS6Bird
02-02-2005, 10:54 PM
can some1 give me specs of teh 305 in the 1984 T/A?
website? info etc. my buddys got one and wants some ideas of how to beat this other kids 89 5.0 Mustang GT
CTSV05
02-02-2005, 11:29 PM
The 84 is carbed still correct?
Assuming I'm right, there are few bolt on that will be of much help, beyond the obvious, headers exh., good dual plane int., etc....
I don't remember for sure what year they started with the roller cams, but I believe it was in '87.
Sadly, the carbed cars were just not quick. And if emissions is an issue then mods will be limited.
Now if testing isn't an issue, than a head and cam change will go a long way in a hp increase.
I had a '80 'Bu wagon, that ran 14.40s with a small cam, .456 lift, and a slightly ported set of sm. chamber Z28 305 heads. The car was 3750 with me in it, a 3:73 gear, all stock suspension.
My point is you can make a 305 run DECENT, but you need to do some work.
02WS6Bird
02-03-2005, 07:15 AM
Thanks for the info-anybody else? mayb some factory info?
pwr2w8
02-03-2005, 06:23 PM
305's aren't the most hot rod friendly motors. I rebuilt one and have 10:1 comp. ratio, good sized cam, rebuilt factory heads(with better springs), performer intake, holley 600 vacuum secondary carb, and block hugger shorty headers. It's at about 250 hp now so you can guess that your friend has less, unless he rebuilt his also(I'm guessing no). They really aren't worth it unless you get your parts dirt cheap or are trying to do something REALLY different.
Just my 2 cents.
FireHawkMike
02-03-2005, 09:32 PM
Just my 2 cents.
check www.thirdgen.org they are tons of info on 3rd gens, scpecialy 305s
Muffracing
02-03-2005, 10:43 PM
Get a 350. They use the same parts but make more power 'cause they're bigger. A friend of mine raced with 305s in a B mod. the engines cost more then a 350 and had a huge toque difference.
AutoRoc
02-04-2005, 07:28 PM
Performer Intake
600cfm $220 Holley carb Vac. Secondary
7.5PSI fuel pressure
1-5/8" headers
3" single exhaust with good muffler
NX Plate Nitrous Kit
3.73 gear
good converter
Slicks
I had my 89 IROC going a sad 15.60 on motor(same as stock tpi actually) and 12.80 @ 108mph on a 150 hit. 13.00 on a 100 hit.
Needed some tuning N/A but I had it set nicely on the juice.
02WS6Bird
02-07-2005, 06:42 PM
Performer Intake
1-5/8" headers
3.73 gear
good converter
Slicks
looks like they like nitrous god damn! lol
does anybody kno the stock specs-Compression Ratio, Cam, Carb, HP, TQ any dyno sheets.
How many years old does a car haveta be for antique plates in IL anyone know-what type of emissions does it need?
02WS6Bird
02-07-2005, 08:35 PM
also is it TPI motor or TBI?
AutoRoc
02-08-2005, 07:21 PM
Your buddy's 1984 305 would probably be the LG4 or L69 model with a Q-Jet carb actually, not TPI or TBI.
Zepher
02-09-2005, 06:31 PM
My 86 Trans Am had the LG4 305, 165hp.
I installed an Edelbrock 7101 Intake and 4106 Carb with an Open Element Air cleaner.
Didn't dyno the car stock but it dyno'd 199RWHP after the swap.
Ran a 14.94 @ 92mph. Engine had a 133K miles on it.
http://www.transamws6.com/pics/transam/Edelbrock.jpg
Zepher
02-09-2005, 06:35 PM
Oh, about 6 months later I wanted to convert to TPI since the carb setup looks so dated.
Video of the car with the new TPI setup on it,
http://www.transamws6.com/video/ZepherWS6.mpg
http://www.transamws6.com/pics/transam/engine.jpg
Wnts2Go10O
02-09-2005, 07:11 PM
getta 350. 305's run like shit but theyll run like shit forever.
84camaroz28
02-11-2005, 01:25 PM
I had an 84 Z at one point.
I would guess it has the LG4 which most had. 145hp 245tq, 8.8:1cr. Don't know any cam specs. E4MC carb, unless it's a cali edition then it has the other carb. Bout the only thing the engine is good for is a boat anchor. You don't have to worry bout emmisions in IL, so swap to a 350! I put the GMPP 350 H.O. in mine with an edlebrock Carb/intake had my tranny built and some 3.73's. she ran mid 13's 101-102 mphall day long in hot ass Phoenix AZ. Then put a 150 shot in and ran a few 12.1's @ 114-115 mph.
Muffracing
02-26-2005, 10:48 PM
[QUOTE=Zepher]My 86 Trans Am had the LG4 305, 165hp.
My old '99 Firebird with the 3.8 is about as quick. :lol:
