Small Block & Big Block Chevy Specific - Hi!
Lurch84
02-06-2005, 08:42 PM
Hi, just found the site while saerching for some info on my motor, i spun a bearing but iam not shure which sb it is it has i cant read the code on the back but on the front it has k1114fja, its in a 85 chevy pickup but i know that the motor is newer due to the fact that the there is no hole drilled out for a mech. fuel pump. Any help is greatly appreciated, i need this so i can order the right parts to fix it!
pwr2w8
02-06-2005, 08:47 PM
welcome to the site. :cheers:
PRAY HRD
02-06-2005, 09:46 PM
hey man......welcome to LS1 Tech. hopefully someone can answer your question or give you an idea how to look that # up if it means anything.
later,
Dave
Lurch84
02-07-2005, 08:35 PM
Well i pulled the pan today they are not spun yeppee, but they are worn bad on one side on the 3 and 5 cylinders i thinking the crank is out of balance since the motor was rebuilt right before i bought the pickup.So iam having a crank balanced and i will put it in and all new bearings this weekend! Thanks for the support!
Villain281H
02-07-2005, 09:13 PM
welcome to the site, and glad to hear the damage wasn't as bad as you thought!
Derek
CTSV05
02-07-2005, 11:16 PM
Welcome! On the newer engines there should be some info in the casting itself. Like on the side of the block, etc...
lifted99
02-07-2005, 11:26 PM
Welcome to the site. Is the motor TBI, multiport, etc?
Lurch84
02-08-2005, 09:29 PM
Not shure what fuel injection it had. This truck was bought by my dad he let me have it when i blew the motor in my s-10 blazer ugh. Would a 472 lift cam be too much lift for fairly new stock springs? Cam is just sitting here and it shure is tempting to go ahead and put it in this weekend!
