Stereo & Electronics - Tachometer installation
RedWS601
02-10-2005, 08:57 PM
Does anyone know how to install a Tachometer? It is an APC don't really like it but was a gift. please help
SSactionLs1
02-11-2005, 04:52 PM
you should have a
parking lights wire
tach wire
power
ground
tach is a white wire on the PCM
Parking lights you can grab right behind the switch, i THINK its brown...power you can get from the IGN harness, i dont remember if you want constant or ign power...constant is red and ign is pink...and ground it to any metal surface..
ArcticZ28
02-11-2005, 06:22 PM
you want ignition power so tap into the pink one... no use in always powering a tach to read RPM's when the car is off.... unless you REALLY want to make sure the engine is off :)
SSactionLs1
02-11-2005, 06:27 PM
reason i wasnt sure is most tachs now have a memory recall...Dont remember if thats stored electronicly or not.
