Stereo & Electronics - Stealth box without cutting the interior plastic??
NufNuffZ28
02-16-2005, 01:18 PM
Hey...I will be purchasing a stealthbox VERY shortly and want one that I do not have to cut up the factory interior out to accept(Drivers side rear plastic panel).
The only one that looks like that is possible with is the Thunderform. http://www.mtx.com/caraudio/images/tForm2004Install_CF10Lrg.jpg
Is this true?? We show the car and I want the install as clean and unobtrusive as possible.
Thanks
Chris
96blackz28
02-17-2005, 06:35 PM
I have that box, its not bad at all. Very stealthy. You dont have to cut anything, it fits right into place.
FelixIlka
02-17-2005, 06:38 PM
Is there any way to put subs back there and still use the Monsoon Stereo?
Phoenix 5.7
02-17-2005, 08:12 PM
your panel is different from mine, i have the entire hole cut out. Do you have the factory sub back there? Y not just go with a subthump box (subthump.com) and trim the plastic or get a panel off of a car with the hole cut out bigger from the factory.
megabass
02-18-2005, 09:04 PM
Only the older cars with the stock bose sub have the filled in panel like in that photo. Does your panel look like that? I doubt it. Very few cars have it. Therefore, any stealthbox will fit and the subthump one a good one.
Phoenix 5.7
02-18-2005, 09:08 PM
he could just get a replacement panel from a junkyard with the hole cut out
megabass
02-18-2005, 09:20 PM
Yep. :)
