Small Block & Big Block Chevy Specific - torque conv.
View Full Version : torque conv.
Fbody Man
02-16-2005, 04:14 PM
hey guys i have a quest. What is the most efficient torque converter out? I have a built up l98 and when my tax check comes in im doin the tranny.
nosfedgta
02-16-2005, 10:30 PM
Is it a tpi car ? or carbed ? let me know your mods and such and I can help you out..
Fbody Man
02-16-2005, 11:31 PM
car is a tpi bored .030 over to 355. Has cam, heads, matched intake manifold accel super ram, forged pistons speed pro moly rings 255lph fuel pump and #30 injectors i will be using nitrous probably 75-100 shot and 1 3/4 slp headers will be changed to hooker longtube 1 3/4 headers and 1.6 ratio rockers for a lift of .540
nosfedgta
02-17-2005, 12:51 PM
depending on what cam you have that is almost identical to what my old 355 was. I ran a 3200 stall and it worked great!!! I would run a 2800-3400 stall for your application. If you want a can get you a converter at a great deal.
Fbody Man
02-20-2005, 03:35 PM
sure what kind of a deal? E-mail me bowtiemadness@hotmail.com
Wild85
02-20-2005, 04:06 PM
make sure it has anit balloon plates on the converter.
nosfedgta
02-20-2005, 08:36 PM
700r4? th350? th400? and what year is the 700r4 if it is one ?? they made diff input shafts in the later years. Also do you want a lockup or non lockup ?
Fbody Man
02-20-2005, 09:52 PM
1989 chevy camaro iroc 700r4 I wanna keep overdrive so yes lockup
AutoRoc
02-21-2005, 07:21 PM
Drew seems to have been around 1 or 2 thirdgens before so I value his opinion on this one. :jest:
On a mild build like this it's definately worthwhile to do something in the 3000rpm area. I'm guessing the cam will compliment the SuperRam in the 2000-6000rpm range and if that's the case, Set aside some money for very good(sticky) tires. :drive:
I'd definately look into a Precision Industries Vigilante 9.5" converter. If that's not your style, YANK or NEAL can set ya up.
I have a Lock-up 4200 P.I. Vigilante and it drives nice so you have nothing to worry about.
nosfedgta
02-23-2005, 11:19 PM
The converter will run you 535.00 shipped to the door. let me know if I can help you..... That is for a 3000 stall antiballon plates, lockup clutch, 2 year warranty, and a 2 year free stall upgrade.
