Small Block & Big Block Chevy Specific - compression
View Full Version : compression
lowchevy
02-17-2005, 09:27 AM
i am building a 383 stroker which i will probably run on the street most of the time, but i'll take her to the track every now and then to see what she can do. my question is if i run a small blower like 6-7 lbs of boost with a set of 72cc heads, will 8:1 compression be good, i know that with a supercharger you want to keep the compression down. i've heard i need higher than this as well as lower than this, who's right? thanks for any help.
Fbody Man
02-17-2005, 10:47 AM
8:1 is good. But u have to run more boost. With 8:1 u can run safely at least 15psi of boost which is really good. U can the 6-7 psi but take advantage of that low comp. and use more boost. Is the motor built u know wit forged internals and all?
lowchevy
02-17-2005, 10:55 AM
yes, forged eagle crank, forged eagle rods, and forged je pistons. i was told that with 8:1 that i would have bad low end acceleration. so if i increase the boost that should fix that problem correct.
thebowtieislife
03-06-2005, 01:20 AM
low compression WITH PUMP GAS, 93 or lower is safe to around 12-15 psi, your 8 to 1 motor should do just fine and still make ok bottom end
Debby SS496
03-08-2005, 10:47 PM
running more boost, your also gonna have to kick that timing back, so make sure you get yourself a good timing retard box. MSD makes a nice unit.
