Stereo & Electronics - Remove coat hooks?
View Full Version : Remove coat hooks?
chupr0kabra
03-30-2005, 12:22 PM
I figure this is as good a forum as any to ask this.
How are the little coat hooks removed from the back seat panels? I can get them to pop out a little bit, but then they catch and I can't get them past about 1/8" removed.
-Mike
OctaneZ28
03-31-2005, 03:02 PM
Use a screwdriver in the little indentation on the bottom of the part that comes out.
Carefully pry out that middle piece.
If I remember right, it's about 2½ inches long total.
Are you taking the sail panels out?
jmilz28
03-31-2005, 08:10 PM
Just pry the MFer out. If they break, get new ones. If you leave them out, you will have even more rattles than before. :)
TDH02
03-31-2005, 10:01 PM
They are a pain to get out, try to pry them out as far as you can then pull evenly on the panel, it should come loose. If not pull harder.
badhoopty
04-01-2005, 01:44 PM
they are tricky little bastards...
i couldnt believe how hard those things were to get out. felt like i was gonna break them.
chupr0kabra
04-01-2005, 02:30 PM
I'm having speaker problems in the back seat passenger side and I need to re-run the speaker wire (the install shop didn't do a great job). If I can pull the sail panel off, it would be much easier. Plus, it would be good to know for future reference.
-Mike
