XtreemeChaos
06-09-2005, 03:11 PM
I'm sort of a newb when it comes to car audio, so here's my question. I know the monsoon system is set up at 2 Ohms and most aftermarket speakers are 4 Ohm, but what determines the Ohm-age (if that's even a word)? Is it the speakers themselves or the amp or both?
What I had in mind was to upgrade my system in stages. If I left the stock HU and stock amp, removed the filler speakers in the hatch, and put aftermarket speakers in the doors and sail panels, would the speakers run at 4 Ohms or would the amp make them still run at 2 Ohms?
The second stage would be to upgrade to an aftermarket HU and add a sub and amp. Then the 3rd stage would be to replace the factory amp with an aftermarket one.
