Dynamometer Results & Comparisons - Dyno'ing an automatic?
TA4U2NV
07-17-2005, 03:56 PM
How would you go about this? I can't figure it out, since if you left it in drive, went up to 4th gear, and mashed it, it's gonna downshift.....which you can't do on a dyno to get a full pull, right? How do you do it?
foff667
07-17-2005, 05:18 PM
I lock it in gear with hptuners & lock the converter...bam done. lol
and use the closest 1:1 ratio gear, which is 3rd in the 4l60e.
obZidian
07-18-2005, 10:26 AM
usually, when un locked, you want to do the run in your third gear. So wat i do is put here in regular drive (or "3rd" gear).... this might be stupid but you know the gear selection i speak of right?...... ok...just checking!!! :)
anyways, bring her up to about 3k and start your run but dont smash the pedal for she might downshift.....you wont get a lower reading like 2500 but it is possible.
When locked....that is easy...just bring her up to 2rd gear and let her have it!!!
Good luck!!
mrr23
07-18-2005, 05:53 PM
so, if you lock the converter, you dyno in 2nd?????? anyways. you dyno in 3rd gear. on both of my cars i run them up to 3200 rpms with the selector in "3". floor it and it doesn't downshift. that's how to dyno an automatic.
