Small Block & Big Block Chevy Specific - Stroking 355 to 383 weight
View Full Version : Stroking 355 to 383 weight
kukri
08-02-2005, 11:11 PM
How much more weight will it gain 383 instead of 355? It matters, because it's going in the rx7 2nd gen.
Thanks.
CTSV05
08-03-2005, 12:43 AM
The weight difference will be negligable. The only real change will be adding a longer stroke crank and a different piston.
Unless you're going from an ultralight crank to a stock crank that is.
white_ta
08-03-2005, 09:54 AM
Yea, there won't be enough weight difference to matter I wouldn't think.
Villain281H
08-03-2005, 12:35 PM
agreed, difference won't be more than a few pounds here and there.
kukri
08-03-2005, 01:22 PM
that's good. i was told that 440 bb weights only a margin more than 383 sb, he might've been talking mopar...who knows
Wnts2Go10O
08-03-2005, 03:43 PM
yup the 440 is mopar
CTSV05
08-03-2005, 04:21 PM
2 Different Animals.
91Z28
08-03-2005, 11:58 PM
Yes, in Mopar land both the 383 and 440 are big blocks.
Strokinit383
08-11-2005, 01:08 PM
The only difference is weight of cranks. The block will actually weigh a little less due to clearancing for the larger crank. It all kind of balances out. Theyve got to be within 5-10lbs of each other.
ProStreetZ28
08-13-2005, 10:57 AM
I agree, the rear counterweight is larger, but you grind a good amount out of the block. I couldn't imagine it being more then a couple of pounds. If you're using a nodular crank caheck out the Eagle the throws have lightening holes through the rod journals. I have pics of that crank in my 385 on my webshots page If the image doesn't show up here's the link. 95/98 Camaro Photo Album (http://community.webshots.com/album/284512165gXUGNz)
http://image32.webshots.com/32/4/97/96/284549796voXAZx_ph.jpg
