Drag Racing Tech - Best rear sway bar? Madman?
Carbed4thGen
08-03-2005, 10:54 AM
Ok guys here's wat I'm looking for. I'm looking for opinions on the best rear sway bar. I'm lookin to make good power (something to get me goin around 8.50 in the quarter all of which is going to be done on a DR so suspension is key) and want something that's gonna stand up to the abuse of a trans break and keep teh car dead nutz straight. Give me some ideas and a listing of best to worse on the sway bar list. Thanx
12secSS
08-03-2005, 11:01 AM
You want to use a solid bar with solid connections. We use the Wolfe anti-roll bar on our car.
Dragaholic
08-03-2005, 11:18 AM
2nd vote for the Wolfe anti-roll bar. You might check into their website because they have both the single and double roll bar. Not sure what the single bar's limits are, might be on the boarder line if I remember correctly.
I would go with a double wolfe or give billengsley a call and have them make you a nice fabbed lightweight 9' housing with their drag sway bar on it if you are planning 8s right off the bat.
I have a Spohn drag bar, its stock type with rod end links. Great bar but its getting to be a pain to put some real shocks on the rear since it almost touches the skinny stock shocks.
The BMR bar is the same basic stock type design but at least it has a little curve to clear the shocks.
ChevyGoldfinger
08-03-2005, 11:45 AM
Another vote for the Wolfe Racecraft anti-roll bar. I have the single, but only plan on going 9.99 at best. Mine has had to be welded twice, (broke at the weld once) so make sure you have an ace welder install it. GL :)
DopeFedZ
08-03-2005, 11:48 AM
Another vote for Wolfe here.
Dan / Wolfe Race Craft
08-03-2005, 12:44 PM
We also have another option available now.
We now have a kit that mounts either a sinlge or double sway bar, to the frame rails above the rearend. Requires that the stock fuel tank not be used.
Dan
Outlaw
08-03-2005, 01:57 PM
Dan
Another vote for wolfe.. and man where was this frame rail mount 8 months ago!!! I would would have loved to have the over the rear end one!
Silent but Violent
08-03-2005, 04:16 PM
Nothing other than the Wolfe for me....
GueSS Who
08-03-2005, 07:08 PM
Wolfe here on all of the cars that I have been involved with.
Carbed4thGen
08-03-2005, 08:06 PM
Dan
Ya I saw that but I'm using the stock tank still, I mean geez its a street car :secret2: So I guess the normal double one will have to do. Can u guys maybe lower the price a bit though? :bang:
ChevyGoldfinger
08-03-2005, 08:15 PM
Wolfe has some nice GP's now and then. I got mine on a GP deal and saved a real nice chunk of change. So if you don't need it immediately, check for the next GP. :)
liftin'em on nittos
carbed...wolfe is in arlington...go by there and talk to them.
Carbed4thGen
08-03-2005, 08:18 PM
Thanx for the Idea Gold but I'm tryin to get the car together quick so we'll see if I can wait :mad:
I may just have to do that
MADMAN
08-03-2005, 09:19 PM
Carbed cheap isnt way to go if you want to go FAST!!!!! I use the Wolfe in 98% of my cars.
Carbed4thGen
08-03-2005, 09:34 PM
Oh I know already dont worry, I wasnt tryin to go cheap, juts cheapER! haha
I'll get on ordering that Wolfe soon. Who wants to run a GP now is the question!
Carbed4thGen
08-04-2005, 07:00 PM
Ok guys next question is does the double wolfe bar allow the use of the stock tank? Cause its a street car and I want to keep it as "street" looking as possible :burn:
GueSS Who
08-04-2005, 07:08 PM
Yes if you do the rearend mounted one.
Carbed4thGen
08-04-2005, 07:53 PM
Ahh that's what I thought good. The frame mounted is new correct?
jay_99z
08-04-2005, 08:56 PM
Guys, how noisy is the Wolfe? I have the extreme BMR sway bar and the solid end links are driving me nuts. Constant rattles.
Thanks
SLowETz
08-06-2005, 10:49 AM
You're gonna have the same amount of noise w/the Wolfe. I run the weld in Wolfe single w/endlinks and it's noisy. I was able to quiet it down a touch by running a small thin rubber washer in the bracket on either side of the link.
Other than that.... it's just like everything else.... you either just get used to it or tolorate it. The gains are worth it.
ChevyGoldfinger
08-06-2005, 11:03 AM
Most people with enough power to need a Wolfe anti-roll bar have enough other noise going on to mask it. :)
I have a 9" w/Detroit locker clacking and whining, along with 4" bullet muffler that takes care of any minor noise my Wolfe bar might be making. Plus, it sure is worth having, the car leaves straight as an arrow, hell you could almost take your hand off the wheel completely. :judge:
Great mod! :hail:
Jimmy P
09-30-2005, 03:53 AM
For someone that wants to keep his stock fuel tank, and wants to get all the traction/stiffening possible, should I get the double? Not sure how fast I will be going, but I would think that 9's might be posibble with a setup down the road in a few years, but for now 10's would be the most I would be able to get, depending on how big of a shot I do and traction..
How much would a shop charge to weld it? Thanks
mongse
10-03-2005, 06:57 PM
I used Wolfe's sway bar on the turbo car and I'm using ALL Wolfe on the Mustang. :D
