Stereo & Electronics - Will 6x9" speakers fit?
View Full Version : Will 6x9" speakers fit?
DarknessC5
08-21-2005, 01:36 AM
I won some 6x9's at a carshow. Has anyone used these anywhere in there F-body? I know the normal sizes are 6.5" just curious if I could fit a 6x9 in one of the spots or not.
Nate_Taufer
08-21-2005, 02:13 AM
without some fabrication you're better off selling them and getting some 6.5's
Nate
Platinum WS6
08-21-2005, 12:21 PM
yea i tried fitting a pair in a friends car and it just didnt work.
DarknessC5
08-21-2005, 04:32 PM
They wont even fit in the hatch panels?
spy2520
08-21-2005, 05:44 PM
The ones in the very back? Its just plastic, you could cut to make them fit. The back is 4x6 ovals i think.
99midnightZ
08-21-2005, 07:51 PM
i put 2 6x9 in the back of my 93 and i have to cut out custom enclosers and use the grills that came with the speakers. it wasnt that bad but remeber you will have to run wire all the way back there which kinda sucked unless you want to hook it to an amp
DarknessC5
08-22-2005, 03:44 PM
Yeah, the ones in the very back. That's what I was thinking... They look big enough to fit 6x9s if they were cut.
CAMAROWITHBASS
08-23-2005, 04:38 PM
i have 6*9s in my sail panels.
DarknessC5
08-24-2005, 04:27 PM
The panels in the back seat? How did you fit them?
10thAnivHawk
08-26-2005, 02:21 PM
I work at best buy and the guys in the back installed 6x9's in the place where my rears were not the ones near the back seat but the ones that are back at the hatch. they had to do a little cutting but I think thats it. I'm very happy that I went with the 6x9's
94strokedz
08-26-2005, 02:35 PM
I took off my plastic panels on either side of my back seat. Then I held the 6 by 9's up to the hole where the 6 and a halfs were and traced where I needed to cut out. Then I went crazy with a sawzall, and it worked out great. No problems whatsoever. I did it to my 94 Z28 as well as a friends 98 firebird. It was pretty easy. 6 by 9's put out much better mids under power than 6 and a halfs do.
10thAnivHawk
08-27-2005, 07:01 PM
No doubt about it you will be much more pleased with your mids. go for it!
InfiniteReality
08-29-2005, 01:38 PM
This will be my next mod...
