Stereo & Electronics - turn signals?
View Full Version : turn signals?
99midnightZ
08-23-2005, 12:54 AM
hey guys i dont know were i should post this but here it goes. my lleft turn signals work fine. although my right signals dont work at all. the light comes on when i turn it on but the signals themselves dont blink and neither does the turn signal light. it just stays solid. whats with this?
ewilborn
08-23-2005, 01:21 AM
you have a bulb out on the right side... either the front or the back
99midnightZ
08-23-2005, 01:40 AM
how can i figure what bulb is out if none of them will come on?
WhiteBird00
08-23-2005, 09:21 AM
If none of them come on then all are burned out. Usually they will come on but not flash so it's easy to walk around the car to see which one is burned out. You can also turn on the hazard flashers so that all the working bulbs will flash then look for the one that doesn't.
rlax31
08-23-2005, 09:23 AM
start with replacing the back, much easier to get to then the front.
the front aren't really hard to get to from under, but the backs are cake
WhiteBird00
08-23-2005, 09:29 AM
Why replace bulbs unless you know they're burned out? Start with replacing the bulbs that are burned out.
99midnightZ
08-23-2005, 02:31 PM
i tried the hazzard lights and none of them turn on. i also replaced them both and they still dont turn on. my turn signal light comes on but instead of blinking it stays solid?
WhiteBird00
08-23-2005, 02:53 PM
OK, I'm getting confused here. Perhaps you should start from the beginning and tell us which lights work and which don't. I thought only the right side turn signals weren't working. If that is the case then the hazard flashers should work everywhere except on the right side where the bulb is burned out. The turn signal light and the hazard lights are the same units so your statement that the hazards don't work but the turn signal comes on and doesn't flash is confusing.
99midnightZ
08-23-2005, 03:54 PM
sorry i got confusing let me start over. my LEFT turn signals work when i turn them on they also work when i turn the hazzards on, although the RIGHT side when i turn the blinkers on, the blinker light comes on but it stays solid(instead of blinking) and outside the car the Right side wont work at all
WhiteBird00
08-24-2005, 10:00 AM
Sounds like BOTH bulbs on the right side are burned out. It's not the switch because you wouldn't see the dash light if it wasn't working. It's also not the flasher because the same flasher does both sides and your left side works. It could be the sockets are corroded or damaged preventing the bulbs from lighting although this usually only happens on the front (the rear sockets are protected from moisture inside the hatch area).
