Stereo & Electronics - LED interior lights
View Full Version : LED interior lights
spy2520
11-06-2005, 11:48 AM
i want to do my dome and mirror lights LED. which brightness is reasonable for the interior of the car? i'm looking at either 27000mcd or 40000mcd.
DONAIMIAN
11-06-2005, 01:30 PM
I say go with the brighter ones. Remember LED's tend to direct light in the direction that theyre pointed, so the light given off by them wont be in the same pattern as the regular bulbs.
Arachnotron
11-06-2005, 02:35 PM
http://www.lastofthebreed.com/Installs/InstallIndex.htm
j3ff
11-06-2005, 04:53 PM
DO NOT get the blue LED.......... I have them and they SUCK as far as brightness, I would have gone w/ the whites if I could do it over, my friend got the whites, and his is actually blue too but like 200x the brightness
dragonZ28
11-06-2005, 05:18 PM
I just did my radio, and here is the final product with 3000mcd super whites:
Removed bulbs:
http://img459.imageshack.us/img459/3827/11010283hc.jpg
Close up of removed bulb and markings:
http://img459.imageshack.us/img459/6087/11010291cw.jpg
Night pictures with radio face off:
http://img470.imageshack.us/img470/881/11010327sk.jpg
http://img470.imageshack.us/img470/4/11010337mm.jpg
http://img470.imageshack.us/img470/7054/11010347hu.jpg
http://img470.imageshack.us/img470/3888/11010353ly.jpg
Finished radio look. These pictures do not do justice. Once you see them in person they look 100 times better!
http://img470.imageshack.us/img470/2240/11010362ip.jpg
http://img470.imageshack.us/img470/1800/11010374ap.jpg
2MuchRiceMakesMeSick
11-06-2005, 09:15 PM
I would go with the 40000mcd. I would want it as bright as possible for my dome/mirror lights because they only work when you open the door or turn them on manually.
spy2520
11-06-2005, 10:42 PM
ok cool, just ordered them. hey dragonz28 that looks pretty damn cool, too bad i dont have my factory radio anymore.
spy2520
11-15-2005, 06:55 PM
i got one more question. say the array of LEDs calls for a 12 or 15 ohm resistor. what would be the harm in using a 10 ohm resistor?
kraaazymike
11-15-2005, 06:59 PM
I wouldnt use a lessor value. Always use the suggested value or higher. Youre at risk of burning the LEDs.
LS1_SS
11-16-2005, 09:11 PM
and if they do light the extra power going to them will reduce their life significantly.
Dragon Z28: With the radio, if I were you, I'd remove the light below the volume button. For some odd reason GM puts more power to that light and it's directly linked to the LCD display on the radio. Mine worked like a charm for about a month but one night it just blew, it took the LCD with it and the only way to fix the LCD was to replace it. Just a heads up!
