Stereo & Electronics - pre amp voltage
1hot91
12-08-2005, 08:11 PM
i need a suggestion on what to use to up the preamp voltage on my head unit?
HiTechGent
12-09-2005, 09:04 AM
Why? What do expect that to do for you?
1hot91
12-09-2005, 07:44 PM
why ask why to a question? i am looking for suggestions because i'm looking into purchasing a preamp voltage booster because the preout voltage is lower then i'd like it to be. the advertised 5volts is more around 2 volts and i'd like to get it closer to 8 if possible.
if anyone has a suggestion on a brand of preamp booster then let me know or something similar. thanks.
marcus769
12-14-2005, 02:20 PM
LOL! I dont know of anything. Most i've seen is like 4.5-5.0 Volts. I'm sure you can be done... Good luck!
KevinWS6
12-14-2005, 02:33 PM
What you need is called a line driver. Alot of companies make them, just get it from a reputable company and you will be fine. This would be my suggestion:
http://www.mobileaudiocontrol.com/dept.asp?d_id=5249&l1=5249
The overdrive and the matrix are both good choices.
thaar
12-14-2005, 03:00 PM
PG makes a good one (TLD66)to boost voltage to 8. This Cadence is also a great line driver http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1278
Do you really think you need one though?
1hot91
12-15-2005, 09:15 AM
thanks for the suggestions, i appreciate it and no i don't think i need one.
