Stereo & Electronics - trip odometer resets
sross
01-13-2006, 09:01 AM
I remember reading years ago about how peoples trip odometers were resetting. Mine has recently started doing that (1999 SS). Is the fix still replacing the entire cluster? Any idea how much it costs? What about getting the mileage onto the replacement cluster? Do I have to have the dealer do it or will the PCM automatically set the reading in the guage cluster? I tried the search but had no luck. Thanks.
AtlantaRTA
01-14-2006, 11:48 AM
The trip odometer will reset when there is a dip in the battery voltage, usually when starting. A weak battery will do this. You may not notice anything wrong with the starting of the car though. My 99 had this problem and I checked with peak max/min hold on my Fluke meter. Repalcing the battery corrected it. I believe in later years they corrected the memory issue so it was not erased in the case of a voltage dip.
BitViper
01-14-2006, 11:52 AM
and I thought I read someplace that the accumulated mileage is part of the cluster..not in t PCM....
Camaroz
01-14-2006, 01:05 PM
Yup That is true.. you dont need much memory to store numbers lol
