Small Block & Big Block Chevy Specific - I need some advise (350ci)
proxemics
01-19-2006, 11:41 AM
hi
I'm new here and I'm planning to start working on my car soon .some data :
87 camaro ,350 ci(taken from impala) ,700 transmittion( taken from 87 caprice)
my questions are
1- what is the best combo (heads,cam,intake,carb)for the 350?
2- If I want to stroke the motor to 383 from were I can get the best stroker parts (good+ not so expensive )
3- If I want to put 454cu in the car do I need to modify the chassis
4- which headers to choose?
forgive my english I'm not an english speaker
GTOTitoLS1
01-19-2006, 12:46 PM
to proxemics ;not bad to start, 350 and 700 trans. The best would be edelbrock parts , there you will find good quality parts for reasonable prices, they have a lot for late model camaro's. try to get their aluminum head kits, already come with what you need, then get a cam kit , if you ask them they will match a cam kit for you, also try summit racing, They offer products from every major company at affordable prices.
proxemics
01-19-2006, 03:02 PM
thank you for your quick replay I will search those companies
but is there any known good combo to start with ?
azzsmasher69
01-19-2006, 05:01 PM
depends on what your doing with the car,building a drag car ,street/ strip car,etc.once you know what you wanna do ,you can be pointed in the right direction
bowtie notch
01-20-2006, 08:49 AM
if your looking for a cheap 12 second car, do vortec heads, performer rpm intake, do the roller conversion and use stock lt1 cam, and a 3000 stall convertor. this gets me 13.5's in a truck, i'm sure your camaro is lighter. if you want to go faster, don't use vortec heads. after you spend the money for bigger spring and machine work so you can run a larger cam, you could have almost bought edelbrock or sportsman II heads.
proxemics
01-20-2006, 02:12 PM
thank you I want to built it to be fun to drive we don't have drag track here I just want it to be cool with some power to go and show (and to miss a little with mustangs:)) it's no problem since 99% of the cars here totally stock in fact If I get aftermarket heads I will be considered heavily modded :)
so If I can built it to be 350-370 hp that will be enough
the 700 trans also giving me a hard time but leave it for later
slow trap
01-20-2006, 03:21 PM
i second the vortech setup but would use the comp cams hydraulic camshaft ,i think the lift is .477/.480 .and a 650- 750 cfm carburetor like a demon.
bowtie notch
01-20-2006, 04:41 PM
i would have mentioned that, but some people are having problems with cams that size. it's hit or miss. and i bet that's a flat tappet, the lt1 is a roller cam so it probably makes the same power in the end.
proxemics
01-21-2006, 01:38 AM
ok now I should search for
Aluminum heads but which size 215 or bigger ,smaller ?
Lt1 cam which year ?
do I need to change the distributor and get MSD ?
Exotic Performance Plus
01-21-2006, 06:16 AM
I have a pair of the recently released Patriot Performance small block Chevy cylinder heads in stock, $1199.00 for the pair. If you combined the heads with a Comp 272 camshaft, a Performer RPM intake manifold, a Holley 3310 750 cfm dual feed vacuum secondary carb, and a set of Long tube headers, you would have a good combination. I have new HEI distributors (made by Mallory) in stock with 50,000 volt coils, for $168.00. Bob
proxemics
01-21-2006, 09:04 AM
hi Bob
That sound good
If I couldn't find what I want here I will contact you
do you have any problem with shipping them abroad ?and how much extra $$ that will cost ?
What LT you recommend for third generation ? (good and not expensive)
