Small Block & Big Block Chevy Specific - Looking for info on BBC swap into 4th GEN..
HouseWS6
01-23-2006, 01:26 AM
Anyone got some info or links for BBC install and fabrication into a 4th gen? Buddy looking into dropping one in his car... Anything will help..Thanks
Carbed4thGen
01-23-2006, 10:13 AM
search button helps
HouseWS6
01-23-2006, 02:09 PM
search button helps
Really? do a search in this forum for BBC or swap for 4th gen and see what it brings up..NOTHING, I did get a PM from someone with some good info form this thread, so thanks for the bump..
Quickin
01-23-2006, 02:51 PM
www.teamprickracing.com
OutlawZ
01-23-2006, 02:53 PM
www.bmrfabrication.com
That's where you can get a k-member to do it as well.... They have them setup for 4th gens with BBC motor mounts...
HouseWS6
01-23-2006, 10:52 PM
Thanks for the links, any idea what firewall or shocktower fabrication is involved? and who would make a header to fit, Kooks?
Quickin
01-23-2006, 11:35 PM
I've gotten some info via e-mail from Fast Times Motorworks about this exact issue. They're putting together a plan for me right now.
I'll be talking to them on the phone tomorrow in detail about it. I'll let you know what I find out. They build a 1,000 hp pump gas BBC that will fit in there.
I'm pretty sure the headers need to be custom made.
Cursed1
01-24-2006, 07:38 AM
Lemons makes a header for a big block in a 4th gen f-body.
Strokinit383
01-24-2006, 10:58 AM
CHA CHING!!!
MountainMotor
03-11-2006, 12:51 AM
Anymore updates? I'm interested too but wasn't for sure what all was involved?
Hot Copper Z
03-11-2006, 09:13 AM
You can use a BMR k-member with out motor mounts and a motor plate and it makes it a lot simpler.BMR also makes a transmission cross member to re locate for a glide if you're going that route.
cwaldt
03-13-2006, 11:18 AM
You can also use a stock k-member like I did and put a 454 BBC in a 95Z. I also was able to get Hooker Headers 2455's to work in there too. If you'll look in this section there are several topics about this swap or just look under all my posts.
NWDragRacer
03-17-2006, 12:38 PM
Here's a couple of pictures of how GMMG did the swap...
http://www.pbase.com/donbe/image/360707.jpg
http://www.pbase.com/donbe/image/360708.jpg
ball597
03-17-2006, 06:17 PM
how far do the 2455's hang down under the car??
xxx
03-17-2006, 10:43 PM
Not bad at all....
ball597
03-17-2006, 11:36 PM
thanks man
I just didn't know if it would be better to run a set of shorties that have the same bends as the 2455's?
Not bad at all....
cwaldt
03-18-2006, 12:13 PM
The 2455's are just a tad bit lower than my transmission pan.
