Small Block & Big Block Chevy Specific - Cooling Problems
View Full Version : Cooling Problems
96WS6TA
01-25-2006, 03:17 PM
I have a 96 WS6 and when it is running the engine heats up normally at first but then it takes off and escalates very quickly. The fans are running because I can hear them. Has anyone else had this problem before? Could someone point me in a general direction?
ls1_doc
01-25-2006, 05:11 PM
is it overheating in town or on the freeway?
96WS6TA
01-25-2006, 06:59 PM
in town
Strokinit383
01-25-2006, 07:29 PM
Is your coolant old or low? Nasty color? My driver just did that, just replaced the coolant and made sure it was full with no air locks and it cools just fine. I would start there first.
96WS6TA
01-26-2006, 02:38 PM
My coolant level is fine. New I will double check on the air locks
Strokinit383
01-26-2006, 03:29 PM
Ive read that one way to remove those vapor locks is to drill to small holes in the rim of the thermostat. It wont effect the cooling any but will prevent the air from being trapped.
