Small Block & Big Block Chevy Specific - BIG BLOCK in a 69
View Full Version : BIG BLOCK in a 69
1 Fine 69
01-31-2006, 12:26 AM
Whats the best big block to put in my 69 camaro? I wanted aluminum block and heads with about 550-600 horse
Villain281H
01-31-2006, 08:13 AM
There numerous ways to build a big block for a 550-600 horsepower set-up. You can buy a 572 crate engine and have the power you want already set-up turn key. You could also build a standard 454-based 496 stroker with a production iron block and out-of-the-box aluminum heads with the right cam and induction to make the power you want for much less $. An aluminum block will cost you some big coin but will save weight over an iron block. But the aluminum block is by no means necessary to make the power you want.Derek
MerlinPro
01-31-2006, 07:20 PM
Airb,
Give up on 427 small blocks?
Well we have big and bigger blocks. All the way to 632.
Just call World sales and Clarence can give you the scoop.
1 Fine 69
02-01-2006, 12:37 AM
427 is my choice for now but im just trying to make sure haha.ill be calling, thanks
1 Fine 69
02-01-2006, 10:39 AM
anybody make the 572 in aluminum block?if not does anybody kow the wieght difference between a 427 sbc and the 572?
foxspy
02-01-2006, 10:46 AM
I have a EFI 502 BBC (http://ls1tech.com/forums/showthread.php?t=421446) for sale.
It made 477rwhp and 619 ft/lbs on a DynoJet.
It pushed my 4250lb truck 7.59@92mph in the 1/8th.
Very streetable.:)
