Fueling & Injection - Trying to make sense of Racetronix injector flow numbers
jimmyblue
02-08-2006, 04:42 PM
I see this for the Delphi/Lucas 42#:
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Static Flow Rate: 48.83 lb/hr @ 58.0PSI (300kPa) or 370gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI
My question relates to the static flow vs the dynamic flow
at 43.5PSI. If I do the math, the 9.96g/pulse, 10mS rep rate
gives me 9.96g/pulse*100pulse/sec*60sec/min=59760g/min.
At 25% open.
That's pretty much like 320g/min, accounting for a 1/4 duty
cycle. Yeah.
Something in that description does not add (multiply) up.
Anyone have an independent data source they know of, that
I could check out? Seems everywhere I look I see this same
description over and over but it makes no sense. If there were
sane numbers I think I could calculate an injector offset time
value (for nominal conditions at least) but this is just whack.
