Stereo & Electronics - System Install Help
View Full Version : System Install Help
BoneSS
02-11-2006, 05:43 AM
What do I need for the amps? One amp is 2000 rms at 1 ohm/4000 peak, the other 1000 rms/2000 peak. JVC 7010 DVD HU, JVC 12 Disc changer on the front side (already have adaptors, etc). The subs are 2 10's (1000 watt rms 4 ohms (wired for 1 ohm load)), and the components are 4 ohm Directed Viper 650.2's receiving 400 watts rms at 4 ohms each. What gauge wires do I need? What blocks, other stuff?
http://www.sonicelectronix.com/item_3935.html
That is the power kit I got ($100 shipped). How about RCA's? Brand speaker wire? Basically I think I have it all but the rca's and speaker wire...and an alternator!
WantedRawb
02-11-2006, 07:37 AM
depends on the brands of amps really...from the looks of the other equipment ya got i wouldnt guess they are like competition or anything so they probably wont push what they rate i would think a 2guage setup would be fine... you can get 2guage amp kits on ebay for like $30 shipped....
SSactionLs1
02-11-2006, 11:38 AM
do you plan to upgrade the battery/alternator?
you should
2MuchRiceMakesMeSick
02-11-2006, 12:41 PM
What kind of amps?
What size fuses.
http://www.streetwires.com/Flash/powerwire.html
BoneSS
02-11-2006, 08:42 PM
What do you think so far, and is there anything else you think I need to add? What is your opinions on brand/gauge of speaker wire, and also RCA's? I know I need to get those still, and probably an alternator.
I am taking out 2 Hifonics Industria Series amps, Infinity Perfect 10.1, JVC HU and 12 disc changer, and a Stinger wiring kit.
I have not decided if I should just bridge the Olympus to 2 channel to give ALOT of power (more than is rated) to the comps, or give the extra 2 channels to some rear speakers???? That is a big question.
Also what rca's I need depends on if I am going to do 2 channel or 4 channel off of that amp. The 2000 peak/1000 rms amp has 2 80 amp fuses, but the 4000 peak/2000 rms amp has no exposed fuses.
Setup:
Components: Directed Viper 650.2's
http://www.sounddomain.com/sku/DEI36065
http://www.directeddealers.com/manuals/og/viper_audio/G550_2_650_2.pdf
Subs (x2): Elemental 110V.2 (4 Ohm)
http://edesignaudio.com/product.php?cid=2&tab=Gallery&pid=13&cur=USD
HU: JVC KD-AV7010 DVD
http://www.caraudiodeals.com/product_info.php?products_id=414
CD Changer: JVC CH-X1500 12 Disc CD/MP3 Changer
http://www.sonicelectronix.com/item_2256.html
Amps:
Hifonics XX Hercules:
http://www.sonicelectronix.com/item_4238.html
Hifonics XX Olympus:
http://www.sonicelectronix.com/item_3030.html
Wiring Kit:
Kicker PKD1 1/0 Gauge Dual Amp:
Boxes:
Driver and Passenger Stealths:
http://www.subthump.com/acamarostealth.htm
Rack (do not know if it is going to work yet):
http://www.subthump.com/acamarorack2.htm
